RV.Net Open Roads Forum: How do you get air into your inside tires?
 > How do you get air into your inside tires?
Big Katuna
Deland, FL
Posted: 04/07/08 09:23am Link  |  Quote  |  Print  |  Notify Moderator
I too, am a believer in no hoses or extensions. I have talked to too many people that have problems. Just buy a trucker style tire guage at a Flying J or any decent size truck stop and a double ended air chuck like the truck stops have.
Once you can accept the universe as matter expanding into nothing that is something, wearing plaids with stripes comes easy.
Tinstar
McKinney, TX
Posted: 04/07/08 09:29am Link  |  Quote  |  Print  |  Notify Moderator
My coach had extenders on it when I bought it. I don't know what brand they are but I have not had a leak in the four years I've owned it.
Never pass up a chance to go somewhere
ArchHoagland
Clovis, CA, USA
Posted: 04/07/08 09:38am Link  |  Quote  |  Print  |  Notify Moderator
I have the valve extenders and they work quite well if they are put on TIGHT.
2004 Monaco
La Palma 36DBD
Two Slides
2 Potties
Workhorse 22 chassis
8.1 gas engine & Allison transmission
6.9 MPG based on a 6,000 mile trip around the U.S.
US Gear Toad Brakes
deandec
El Dorado Hills, CA
Posted: 04/07/08 09:44am Link  |  Quote  |  Print  |  Notify Moderator
My MH has metal extenders (not braided). They are now 13 years old and on the third set of tires with about 70,000 miles of use.
Dean
95 CC Magna Jeep GC
(Vietnam Vets may be eligible for medical care and disability compensation. Contact the VA if you have prostate cancer or type 2 diabetes.)
thgoodman
Emery, SD
Posted: 04/07/08 09:48am Link  |  Quote  |  Print  |  Notify Moderator
deaop01 wrote:
Hi,
I also lost a tire to extenders. At the price of tires I got Borg valve stems. Cost $100 plus $80 to have them installed. New tires will last 5-6 years. $30-35 per year is good insurance. Also I can check and air the rear tires from the outside and can check them often. Check them out at www.borgtiresupply.com
Hope this helps
Ron
Ron, thanks for your post. I checked their web site. Couldn't tell if they have what I need. They mention cast outer, steel inner. I have cast inner and outer. I'm going to give them a call.
What was your experience with them? How were they to deal with? Did you go to their store in person or mail order?
Thanks again,
Tom
Tom & Jan
Fulltimers since April '06 with 3 fur kids (George - mini Aussie, Archie - mini Poodle, Kitty - 20 yo blind cat)
1991 Beaver Contessa towing 2006 Subaru (4 down)
Started workamping Sept '07 - This isn't too bad. Think we'll do it some more.
jim_martin_pa
Philadelpa, PA area
As I understand the valve extensions mentioned in this thread are for 22” wheels. If you have 19.5” wheels these extensions will not work.
So the dual wheel extenders (steel flex tubing) make it easy to check and fill the rear duals. We had them installed as part of our purchase package. To date we have had no problems.
Good luck
Jim
2006 Allegro 32 BA
on '06 Ford Chassis
2006 Saturn Ion 2
F373167
Jim's RV Tips
david_w28
Michigan
Posted: 04/07/08 10:16am Link  |  Quote  |  Print  |  Notify Moderator
I don't use extenders and can fill my inside dual just fine although it is a pain in the you know what. I will be adding them as soon as it gets a little warmer outside.
RNDad
Northern Massachusetts
Posted: 04/07/08 10:44am Link  |  Quote  |  Print  |  Notify Moderator
I'm a little confused... I have the Borg valve stems on my 19.5" rims! Works great and easy to use. This is my second MH to have them and I wouldn't have it any other way. BTW, ordered by telephone, great to deal with.
Scott
"Life may not be the party we hoped for...but while we are here we might as well dance!"
F393136
2001 Itasca Sunflyer 36W
2002 Sunseeker 2900 LE (3rd RV)
1998 Forest River Wildwood 37BHSS (2nd RV)
1977 HopCap 23' on a Ford E350 (1st RV)
dapark
SLC, UT
Posted: 04/07/08 10:52am Link  |  Quote  |  Print  |  Notify Moderator
Crossfires IMO are the only way to go. I tried many different extenders etc and after putting these on, nothing else like them. Single fill ability for both wheels keeps them equalized, which is a very good thing. If one blows, the main valve shuts air off automatically. I also like the fact that on the crossfires that I bought, I can still utilize my pressure pro sensors to monitor each tire independently.
2005 Allegro Bay 37DB WH22
1999 Durango is the Toad or
the Milan or the ATVs. Depends on
our compass heading.
D & M
Laurel, MD
Posted: 04/07/08 11:03am Link  |  Quote  |  Print  |  Notify Moderator
Get yourself a set of Crossfires or Cat's Eyes. Truckers use them. They are a little pricey but worth it.
Have had Crossfires for 3 years with no problem. One point to air up both tires, keeps the pressure equal in both tires, and you can keep an eye on the pressure at fuel stops.
Dave & Mary
Isabel (a cuddly little Boston)
Buddy (The Beast) another Boston
2005 Itasca Suncruiser 35A
2003 Jeep Liberty
If it's listed in the Yellow Pages, the government shouldn't be messing around with it.
