RV.Net Open Roads Forum: How do you get air into your inside tires?
 > How do you get air into your inside tires?
Jwasnewski
Dahlonega, GA
Posted: 04/07/08 11:49am Link  |  Quote  |  Print  |  Notify Moderator
Forget the extensions. Do it correctly and you will not have any more problems. www.duallyvalve.com. I have used these with PressurePro for over a year and I have not needed to add air yet.
RNDad
Northern Massachusetts
Posted: 04/07/08 12:04pm Link  |  Quote  |  Print  |  Notify Moderator
I like the idea of the "Crossfires or Cat's Eyes". Went to their websites, but no pricing information? Anyone have any idea how much?
Scott
"Life may not be the party we hoped for...but while we are here we might as well dance!"
F393136
2001 Itasca Sunflyer 36W
2002 Sunseeker 2900 LE (3rd RV)
1998 Forest River Wildwood 37BHSS (2nd RV)
1977 HopCap 23' on a Ford E350 (1st RV)
dapark
SLC, UT
Posted: 04/07/08 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
Scott, They will run you abut $65.00 per side (mine did) but they also had the additional valve on each line to allow me to continue using the pressure pros. I don't know if this adds to the cost but I bet this is close regardless. I bought mine from Donely Enterprises. You can find his information on the locate a dealer link under KS(Kansas). I was pointed in his direction because he had the type of crossfires I wanted for the pressure pros but other dealers (maybe even local to you) can get them.
2005 Allegro Bay 37DB WH22
1999 Durango is the Toad or
the Milan or the ATVs. Depends on
our compass heading.
deaop01
Mansfield, Ohio
Posted: 04/07/08 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
I called them. They are nice to talk to. I ordered from them over the phone.
I have 19.5 wheels (steel). I think they have them for 22.5 also, you need to call.
These are valve stems not extenders and need to be installed ( cost me $20 each tire ).
Good luck
Ron
Betty and Ron
2002 Bounder 31W
8.1 with 5 speed Allison
2 slides
2005 Colorado toad
Bndr Rick
Rosamond, CA
Posted: 04/07/08 10:57pm Link  |  Quote  |  Print  |  Notify Moderator
Will,
The straight braided extensions for inside duals do not have air in them until you apply the air chuck. They have long core extensions in them that push on the valve stem core when an air chuck pushes them.
You can get a rubber plug for the outer aluminum rims that will stabilize them.
We have had them on our 2001 Bounder and now on out 2002 Dutch Star DP with no problems.
Sure makes checking them easy, which I do at every stop.
Rick Clark 2002 DSDP 3852, Spartan MM, Cummins ISC 350, '98 TJ Toad
http://s205.photobucket.com/albums/bb317/rickca55/
http://www.cardomain.com/ride/2090792
Will_Robinson
Charlotte, NC
Posted: 04/08/08 06:09pm Link  |  Quote  |  Print  |  Notify Moderator
At truck stops, do they have the angled chucks, straight chucks (which is all I really need) or does it vary?
J & S
Kayla,Gertie & Cheyenne "The Stepford Dogs"
2007 Country Coach Tribute 260 Touring 40' Quad Slide
2007 Honda CR-V EX
Roadmaster Sterling/Brakemaster
