RV.Net Open Roads Forum: General RVing Issues: nitrogen in tires
 > nitrogen in tires
ol Bombero-JC
Posted: 04/11/08 02:30am Link  |  Quote  |  Print  |  Notify Moderator
JUrban wrote:
I've got about 80% N2 in mine and it didn't cost a cent.
John
Never got past 78% - 80% must be good clean air from "somewhere", LOL!
TZScales
Maryland
Posted: 04/11/08 06:14am Link  |  Quote  |  Print  |  Notify Moderator
It's my understanding that nitrogen is great; however, if you lose any pressure at all you'll need to have another nitrogen source to refill.
TZS
JUrban
Delaware
Posted: 04/11/08 10:58am Link  |  Quote  |  Print  |  Notify Moderator
ol Bombero-JC wrote:
John
Yeah, everyone claims the O2 leaks out so I claimed a 2% bonus. LOL
John
2008 Tiffin Allegro Bus 40' QSP
2006 Chevrolet Colorado Toad
BlueOx Aventa LX Tow Bar
SMI Air Force One toad brake
Copilot Live Laptop 10 GPS
flyswamper
Calgary, Alberta, Canada
Posted: 04/11/08 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
BCSnob wrote:
Okay, I've thought about it. Here's one for you. On drag racers do the tires burn from the outside in or the inside out (due to heat from friction just like on an airplane)? There is more air circulation on the outside of the tire which should be cooling the rubber faster than on the inside of the tire.
Mark
Mark,
Yes the outside edge of the tire/rubber is the hottest spot... that is where the majority of the heat is generated...so it will always be hottest at the heat source.
Yes the outside air will dissipate the heat faster than to the inside.
A higher rate of cooling (HEAT FLOW) to the outside doesn't mean that the outside edge will be at lower TEMPERATURE.
Not sure what else you are getting at or seem to have a problem with????
Constructive disagreement is encouraged. It is how I/we learn!
Dad,Mom, & 3 young'ns
Current Home (Calgary)
keywestrv
key west fl
Posted: 04/13/08 06:54am Link  |  Quote  |  Print  |  Notify Moderator
Mark
Drag racer's tires are burned off from the outside in. That's one of the reasons we use nitrogen...the immediate temp increase does not affect tire pressure, which in our sport is measured in fractions of a PSI. The purpose of the burnout is to clean the tires and give them a tacky, sticky surface in order to prevent spinning them at launch.
She goes really REALLY FAST
2002 Rexair 40' DP Cummins 400HP with Banks
Suzuki GS 290HP Top Gas Dragbike, 0-180mph in 7.5 seconds
Suzuki GS 230HP Bracket Dragbike, 0-150mph in 8.5 seconds
Enclosed race trailer, A/C, gen, compressor, mini-shop
klenger
Tucson AZ
Posted: 04/13/08 07:23am Link  |  Quote  |  Print  |  Notify Moderator
Why are members here calling "air" "O2". Air is less O2 than it it N2.
Dodge 2004.5 3500 CTD
Artic Fox 27-5L 5th Wheel
General RV Mods & Info
RV Solar - Onan Generator - Towing Weights
Digital T-Stat - Photo Album - RV Links
Retired since 2016
 > nitrogen in tires
