Bigfoot43
Fair Oaks, California
My living room slide out is not working. I am not getting power to the slide motor. The wires to the slide motor are relatively heavy compared to the wires at the slide switch inside. That makes me think there is a relay that the switch activates. Where is that located? If that is not how it works can you shed some light on what the problem might be?
Thanks Bob
tuckerin
morristown, ny
The relay is generally near the motor, you should check the slide switch first, the cheapos that make the units generally install AC rated switches instead of DC rated type, a major mistake that showes up in a year or so, use a jumper wire to simulate the switch action
