RV.Net Open Roads Forum: Plugging the trailer power cord into an inverter??
 > Plugging the trailer power cord into an inverter??
La_Bolt_Fan
Los Angeles, CA
Posted: 04/07/08 09:08pm Link  |  Quote  |  Print  |  Notify Moderator
I just got an 800w inverter. Not installed yet but I clamped it onto the battery. Just for kicks I plugged the trailer power cord into it, the inverter said it was sucking 700w from the trailer and nothing in the trailer was on, lights, etc.... I went inside and I could hear the converter running, (charging the battery, I assume). I thought, what was the load?? So I went into the converter/battery charger panel and turned off a breaker that was marked "General". The noise stopped and the inverter said 0 volts being pulled from the inverter. I turned on all the 12v lights, the shower fan and the range fan. Still 0 watts on the inverter. All the outlets worked (120v) and I plugged a drill into a 120v receptacle and turned it on, the inverter showed 235 watts. Also the fridge switched to propane. I am assuming that all the 12v accessories were running directly from the battery, and the 120v plugs are running from the inverter. I am kind of confused!! Has anyone done this? Is this NOT the "Proper" way to utilize an inverter?? Damage to the electrical system? It sure beats running an extension cord from the inverter in the basement to the bathroom for her curlers and things. Thanks in advance for your input!!
Backpacking one week, RV'ing the next!
Chuck&Gail
In the Colorado Mountains
Posted: 04/07/08 09:34pm Link  |  Quote  |  Print  |  Notify Moderator
Just one point. 800 watt inverter should put out just under 7 amps at 120 VAC. I think curling irons often take LOTS more current than that. So IMO what you are doing is ok, but be careful not to exceed current rating. I assume you fused it.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
2oldman
WA
Posted: 04/07/08 09:46pm Link  |  Quote  |  Print  |  Notify Moderator
There's nothing wrong with plugging the trailer into the inverter. Just be sure to:
-turn off the water heater
-refridge on gas
- turn off converter
-don't run the air!
La_Bolt_Fan
Los Angeles, CA
Posted: 04/07/08 09:54pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks guys!! And Chuck, The instructions on the inverter said to put a fuse when I hardwire it, so I will be sure to do so, thanks.
Dixonmatco
Santa Rosa, California
Posted: 04/07/08 10:06pm Link  |  Quote  |  Print  |  Notify Moderator
I do exactly the same thing. I mounted a 1500W inverter just inside the front pass-through and hard wired it with #4 through the floor to the batteries through a 200A fuse and a cut off switch. I set up a 30A outlet for the trailer shore cord to plug into. I make sure that the refer and Water heater are on LP and the converter is switched off. Long after quiet hours, I have 110v for the flat screen, DVD and anything else I choose. It will run the microwave for a short time, but that is a power hog. Upgraded to a pair of 6v batteries and a PD9260 to charge them up with my Honda and I have all the power I need for any situation.
2000 Chevy Silverado 1500
2005 Komfort Trailblazer T23S
Honda EU2000I
JTMO
Novato, CA
Posted: 04/07/08 10:47pm Link  |  Quote  |  Print  |  Notify Moderator
When you had the converter breaker still on; you were sucking power from the batteries, through the inverter, to the converter, to charge the batteries that you were sucking the power out of to use the inverter to run the converter to charge the batteries that ran the ........
A big loop, with big losses in every step
Now, let's discuss time travel conundrums
Cedar Creek 27LRLS 7359 dry with extensive options/7700+ loaded.
2003 Expedition 5.4 FX4 with factory Tow 3.73 Bilstein shocks. GCVWR 14500, Tow rating with no cargo 8650
Equalizer Hitch, Prodigy, Barker Electric jack. Coachnet ERS
Rallies=8
My travel albums
La_Bolt_Fan
Los Angeles, CA
Posted: 04/07/08 11:52pm Link  |  Quote  |  Print  |  Notify Moderator
Exactly JTMO
So I guess turning off the charger is the thing to do, NICE!!
MarionMedic
Marion, MS
Posted: 04/08/08 02:07am Link  |  Quote  |  Print  |  Notify Moderator
Now put some MONDO solar panels on the roof and you'll never need to plug in again.
1997 Chevy 3500 LWB Crew-Cab Dually 6.5 turbo-diesel
2005 Jayco JayFlight 29BHS
Kajtek1
CA
Posted: 04/08/08 03:59am Link  |  Quote  |  Print  |  Notify Moderator
Loop is one way to waste the energy, but converters are known for doing this well alone. I just purchased Kill a Watt meter and played with it. The old converter in my trailer/ plugged into the shore power takes 70W with nothing turned on.
Pessimist sees dark tunnel, optimist sees a light at the end, realist sees lights of coming train.Engineer sees 3 idiots on the tracks.
