CactusJohn
Scottsdale, AZ
I suggest you padlock your hitch handle latch and consider getting a BedSaver, which is cheap insurance.
2007 Ameri-Camp Summit Ridge SF27RK 5er
2008 F250 Lariat SuperCab, 6.4L PSD
Reese 16K Kwik-Slide with BedSaver
Power Stroker
Port Charlotte, Florida
Purchase a $160.00 insurance policy ( BED SAVER ) for that senior moment.
DUNE DUMMY 29
EL CENTRO, CA.
Power Stroker wrote: Purchase a $160.00 insurance policy ( BED SAVER ) for that senior moment.
I have heard of those but have not seen one. I definitly wil buy one. The hitch is a super slider & was professionally installed. I don't have the F-250 with me right now, but from my memory I can't figure out how I am going to padlock the lever. the hitch has 2 padlocks.
edited 04/09/08 03:50pm by DUNE DUMMY 29 *
45 MINUTES FROM GLAMIS
2008 WEEKEND WARRIOR CL4005
2006 F-250 4X4 SUPERCREW DIESEL
2005 YAMAHA YFZ 450
2000 HONDA TRX 400EX
1999 EZGO
Vulcaneer
Northern New England
As far as I know, Bed Saver is not currently available for anything but the 16K SuperGlide.
To lock your SuperGlide, place the padlock thru the hole where handle slides. This takes up the space needed to lift the hitch to unhook. With the lock in there, the handle cannot be lifted up.
2006 F350 V10 4X4 SC SB SRW 4.30 22,500 GCWR
Keystone Sprinter 33'9" 12,500 GVWR
Pullrite Super Glide 18K
Super Duty, Super Cab, SuperGlide
DUNE DUMMY 29
EL CENTRO, CA.
Vulcaneer wrote: As far as I know, Bed Saver is not currently available for anything but the 16K SuperGlide.
I know mine is a Pullrite I will have to check it out this evening when I get home. These pix were taken when the incident happened.
edited 04/09/08 02:33pm by DUNE DUMMY 29 *
camping man
Central Fla.
Sorry to hear that, lucky their wasn't more damage. I have a Sig. series
hitch, and several times it looked hitched, but when I went to put the safety pin back in the hole, it wouldn't go in because of some safety lever device on my hitch, so sure enough I check it, and it wasn't locked, it was sitting high on the hitch like mentioned. Now I always make my truck fight a little to get under the trailer to make sure it's right.
05 Dodge 2500 Quadcab CTD NV5600/3.73rears
97 27ft.Sprinter 5er
Website
DUNE DUMMY 29
EL CENTRO, CA.
I don't know if it makes a difference, our trailer is a toyhauler & there is an extension plate on the trailer pin.
Dieselgem
Pennsylvania
It looks like you have a short bed and a slider hitch. It is possible that you hitched high, sprung the handle and thought you were good to go. I had a superglide on my last truck and a regular pullrite on this one. I always look inside to be sure the jaws have closed. Good habit to get into.
08-KZ Escalade 41'CKS Escalade Pics
2008 F450 Super DutyTruck Pics
97 & 2003 FLSTS
2003 FLSTC (Wife's)
Vulcaneer
DUNE DUMMY 29 wrote: I don't know if it makes a difference, our trailer is a toyhauler & there is an extension plate on the trailer pin.
That is likely the SuperGlide capture plate. The "V" key under the plate engages the hitch plate so the hitchplate turns with the trailer angle. It is supposed to be there to make sure the SuperGlide slides back and forth automatically as the truck turns.
DUNE DUMMY 29
EL CENTRO, CA.
Dieselgem wrote: It looks like you have a short bed and a slider hitch. It is possible that you hitched high, sprung the handle and thought you were good to go. I had a superglide on my last truck and a regular pullrite on this one. I always look inside to be sure the jaws have closed. Good habit to get into.
I checked out the pix of your toyhauler. Very nice.
