RV.Net Open Roads Forum: Towing: Towing Saturday without sway control.
Search only in Towing
Open Roads Forum  >  Towing
 > Towing Saturday without sway control.
ChrisAC
Baltimore, MD and Washington, DC
Posted: 04/09/08 12:24pm Link  |  Quote  |  Print  |  Notify Moderator
Hello,
We're trading in our ROO 233 hybrid (24ft. 3700lbs.) on Saturday & leaving with a Wildcat 30LOFT fifth wheel.
Here is my question.
I have a new tow vehicle for the new 5'er. (sig. below). I am going to use this vehicle to tow the ROO back to the dealer (45 miles).
But the Equalizer hitch I have is setup and aligned for our old T.V. (Toyota 4Runner), hitch receiver is about 2 inches lower on the Toyota.
Do you think I'll have much trouble towing the ROO with a standard W.C. hitch I have? Or would you recommend that I connect the Equal-i-zer & bars to see if the bars would not be too loose?
I assume if the bars are too loose, the weight distribution & sway control features are nullified.
Thanks for any info,
Chris
Chris & Debbie
Alison & Emily - 12 & 6 yrs old
Senior Lab Hershey RIP 4/4/08 16 yrs old and her daughter
Kiara - 9 yrs old.
2003 Silverado 2500HD SB CC 2WD D/A
2009 Wildcat 30LOFT 5'er - Reese 16K Kwik-Slide
& Prodigy
great dane camper
Michigan
Posted: 04/09/08 12:48pm Link  |  Quote  |  Print  |  Notify Moderator
You should be fine, I tow a 6500# work trailer all the time with a w.c. hitch and no problems. 16' enclosed with all my work tools in it and you dont even know it is back there.
Great wife, son, dogs, and camping experiences to remember for a lifetime. Life is short, go camping!!!
sclark
Minnesota
Posted: 04/09/08 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
No problems towing with your new rig. Good luck with the WC.
2004.5 Dodge Cummins
2007 Wildcat 32QBBS
Pair of Honda 2000 Watt generators
ib516
Sask, Canada
Posted: 04/09/08 01:00pm Link  |  Quote  |  Print  |  Notify Moderator
Just make sure the trailer is not too "nose high". That causes it to "walk" left to right and can cause a severe sway.
TT is a 2004 Cougar 301 BHS -- (6580# Dry, 9000# wet)
TV is a 2002 Dodge CTD 2500HD 4x4 w/3.55
Being replaced by a:
2007 Dodge/5.9L Cummins 3500 SRW Megacab 4x4/3.73
PICTURES
ELIM 3000 Gen
Collision Reconstructionist
MEGACAB CLUB MEMBER #1
samsontdog
Sac. Ca summer, Yuma Az winter
Posted: 04/09/08 01:07pm Link  |  Quote  |  Print  |  Notify Moderator
I would not think you would have a problem towing without
samsontdog
Jerrybo66
AZ
Posted: 04/09/08 01:23pm Link  |  Quote  |  Print  |  Notify Moderator
You now have a real truck and not just a toy. It will handle the Roo with no problems.
Support the Country you live in or live in the Country you support
2003 Sierra SP 26'Toy Hauler
1997 F-350, PSD, 4X4, red Crew Cab, long bed.
2007 Arctic Cat Prowler, Arctic Cat 500
ChrisAC
Posted: 04/09/08 01:24pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the replies folks! It makes me more comfortable.
Last trip for the ROO is to the knackers (I mean dealer) sigh!
Gotcha, hopefully the tongue weight will help some (but I'll definitely measure & eyeball)
Chris
ChrisAC
Posted: 04/09/08 01:27pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks,
Chris
mkirsch
Rochester, NY
Posted: 04/09/08 01:34pm Link  |  Quote  |  Print  |  Notify Moderator
Now hold on a second here....
Sure, the truck will handle it, but will the trailer?
This is not so much about weight, but SWAY. Have you ever towed the ROO without sway control? You may have a bucking bronco on your hands, and never knew it until you discovered the trailer resting comfortably, upside down in your brand new truck bed!!!
Travel trailers are often balanced with minimum tongue weight to allow them to be towed by smaller tow vehicles. This makes them inherently unstable. When you're pulling with your 1/2 ton pickup or midsize SUV, you absolutely NEEDED the weight distribution, and the WDH came with sway control.
cummin strong
Wisconsin
Posted: 04/09/08 01:55pm Link  |  Quote  |  Print  |  Notify Moderator
If it is a short distance I will not hookup my WD when towing my 26' trailer without a problem. You should not have any issues. Your trailer is not that heavy and you have a nice big truck. Just make sure there is enough weight on the tongue....In fact I just did it a couple of days ago....
'05 3500 Dodge CTD
Palomino Puma 26' FBSS
