RV.Net Open Roads Forum: Fifth-Wheels: 5th Wheel Hitch Location
 > 5th Wheel Hitch Location
Navychop
Fairfax, VA, US
Posted: 04/10/08 07:11am Link  |  Quote  |  Print  |  Notify Moderator
You say LWB. I assume that means you have a LB. Absolutely not correct. Check my sig. And re-read hankpage. You will now have 2, maybe 4 extra holes in your bed. And it isn't safe to tow that trailer. NOT SAFE.
I installed my own rails, so I know whereof I speak. BTW- I don't recommend installing your own rails. But that's a thread for another day.
You MUST take action on this. Get Reese involved. Might be lawyer time. Act immediately.
2004.5 Dodge 3500 Laramie Quad LB SRW CTD 48RE 4.10 4x4
97 30' Coachmen Royal TT traded in April '08 on a
2008 Keystone Challenger 35CKQ fifth wheel
Air Safe 25K air hitch
Kipor 3500Ti (avoid- no support)
sanderson.66
Ontario, Canada
Posted: 04/10/08 09:19am Link  |  Quote  |  Print  |  Notify Moderator
This is precisely why I sat under my truck for the better part of a day and did my own install. I trust my own work much more than some stranger who won't be riding in the vehicle. The B&W I put in my truck last week landed so the pin will be slightly ahead of rear axle. The install you received is not even close to right. They must have let the green horn do it. I would NOT let them have another crack at it! IMO you definitely have the upper hand as far as negotiating their paying for a QUALIFIED installer to do a re/re of the hitch. Good luck with it. Would like to hear how this all turns out for you.
2007 Dodge Ram 3500 Laramie, CTD 6.7, 6 speed auto,DRW,QC,LB,4X4
2008 Jayco Designer 35RLTS
mowermech
Billings, MT
Posted: 04/10/08 09:32am Link  |  Quote  |  Print  |  Notify Moderator
The installer is not only wrong, he is at least a fool, possibly an idiot. To say the manufacturers instructions are wrong is quite possibly the stupidest thing I have ever heard. Contact Reese, and let them know what this fool did, then contact a lawyer. Having extra holes in the bottom of your truck is unacceptable, when it is the result of poor workmanship. Your truck bed should either be repaired or replaced, and the hitch installed correctly, exactly according to the intructions.
I, too, installed the hitch in my truck myself, mainly because I was too cheap to pay the $250 installation fee. It isn't THAT difficult to do it RIGHT!
Make them fix it, AND they can also fix the truck bed!
CM1, USN (RET)
'94 Dodge 3500 4X2 CTD, Std. cab, LB, 5 speed, 4.10 LS diff., Jacobs Rambrake, 273,000 Miles
'99 Monaco McKenzie 32' triple slide
'95 Tioga 29H Ford-based Class C
Daily driver: '06 Jeep Liberty CRD
Towed: '06 Jeep Rubicon Unlimited
Dennis Bham
Alabama
Posted: 04/10/08 09:36am Link  |  Quote  |  Print  |  Notify Moderator
Like everybody else has said ... this is not acceptable.
It should be over the rear axle or up to a couple of inches in front of the rear axle. It must be moved IMO.
Dennis
'08 Chevy 2500HD Duramax 4x4, Crew Cab, Std Bed e/w 18K Superglide
'08 Cougar 292RKS, e/w 16" Sendel wheels & BFG Commercial TA tires
PressurePro TPMS
jdog
Some Place
Posted: 04/10/08 09:59am Link  |  Quote  |  Print  |  Notify Moderator
Did this clown drill your truck frame? He really messed up if he did!
slotsavegas
Fort Worth
Posted: 04/10/08 02:37pm Link  |  Quote  |  Print  |  Notify Moderator
I apologize if I am way off base here, but you do not say if the hitch is a slider or not. Could it be that you simply have it in the rear position ???
jdog
Some Place
Posted: 04/10/08 02:47pm Link  |  Quote  |  Print  |  Notify Moderator
YES, do answer this one. A slider would put it back 10". But then why would someone put a slider in a long bed?
USAFBILL
Alabama
Posted: 04/12/08 11:30am Link  |  Quote  |  Print  |  Notify Moderator
I wish I had thought of this, and should have as I have a slider...the only explaination (I hope)
jdog
Some Place
Posted: 04/15/08 03:29pm Link  |  Quote  |  Print  |  Notify Moderator
Herbert, where are you. We really would like to know if you have a slider hitch or not?
jdog
Some Place
Posted: 04/17/08 05:47pm Link  |  Quote  |  Print  |  Notify Moderator
I guess he rode off into sunset never to be heard from again.
