RV.Net Open Roads Forum: Tech Issues: Electrical nomenclature question
 > Electrical nomenclature question
Bobbo
Memphis, TN
Posted: 04/10/08 07:21am Link  |  Quote  |  Print  |  Notify Moderator
I know what an SPST switch is. I know what an SPDT switch is, I have always heard it called a "3 way switch" because it can be ON/UP, ON/DOWN, or OFF. What is the correct name for a "4 way switch", you know, the one that goes between 2 SPDT (3 way) switches to give another place where the power can be turned on or off. A DPDT switch doesn't seem right since it seems that it would switch both hot and neutral rather than just crossing the 2 output lines across the 2 input lines.
Bobbo, Linda and the furry kid (German Shepherd)
'07 Winnebago Outlook 31C on a Ford E450 Super Duty Chassis
NRA Life Member
Near N35 12 17 W89 50 57
MudChucker
Winnipeg Manitoba
Posted: 04/10/08 07:36am Link  |  Quote  |  Print  |  Notify Moderator
Well... where to start...
First, your answer depends on what school your from.
a common 3 way switch is SPDT, or SPCO for either "Single Pole Change over" or, Single Pole Center Off"
a 4 way switch is often refered to as, DPCO.
Double pole changeover or Double pole, Center off. This switch is equivalent to DPDT. DPCO is a term used for switches with a stable off position in the center and DPDT for those switches without a stable center off.
There is also one more type of 4 way switch typically found in DC applications, a DPDT switch internally wired for polarity-reversal applications.
Hope that helps.
2006 Springdale 292BHLS
2007 GMC Sierra 2500HD SLT 6.0
MudChucker
Winnipeg Manitoba
Posted: 04/10/08 07:37am Link  |  Quote  |  Print  |  Notify Moderator
one more point to note, some 4 way switches (usually the polarity reversal units) are refered to as "Intermediate Switches"
hemi-kz
Eastern PA
Posted: 04/10/08 07:52am Link  |  Quote  |  Print  |  Notify Moderator
A 3-way switch is called 3-way in electrician nomenclature because it has 3 connections (the ground screw doesn't count). In electronics it's called a SPDT.
A 4-way has 4 connections. It is not a DPDT (which would have 6 connections).
2007 KZ 22 Sportster Hybrid Toy Hauler
2003 Dodge Ram 2500 4x4 Hemi Quad Cab Short Bed
1990 Harley Electra Glide Classic
2005 Harley Sportster 883L
enblethen
Moses Lake, WA USA
Posted: 04/10/08 07:56am Link  |  Quote  |  Print  |  Notify Moderator
A three way switch used in a residential, is a 2 position switch. The black scre is a common the two silver screws are what are called travelers to another 3-way switch.
A 4-way switch used in residential is a 2 position switch with three silver screws for the travels to the 2 3-way switches used in the circuit.
A double pole/double throw switch used in some 120/240 volt applications, opens both sides of a circuit, such as a motor or water heater.
Don't get these confused with DC application switches. Double pole/ double throw switches as MudChucker stated is used for reversing power in such applications as jacks.
There is in both applications a three position switch. These can have many different applications in DC circuitry. They can be on/off/on, they could be on/off/on momentary.
Bud
Suzuki XL7 pushing Pace Arrow
MudChucker
Winnipeg Manitoba
Posted: 04/10/08 08:27am Link  |  Quote  |  Print  |  Notify Moderator
true in terms of nomenclature...
the poles are not always on the outside of the switch.. some are internal
here are IEC 60617 Graphical symbols for 4-way DPDT/DPCO and Crossed.
MudChucker
Winnipeg Manitoba
Posted: 04/10/08 08:30am Link  |  Quote  |  Print  |  Notify Moderator
very good post... I should have been more clear on that crossed switch for DC applications, thanx for point that out a little more clearly.
One point I see you gently touched on that I also forgot to mention is that these switches also all come in, make-before-break, break-before-make configurations as well.
enblethen
Moses Lake, WA USA
Posted: 04/10/08 09:02am Link  |  Quote  |  Print  |  Notify Moderator
Configurations can get really confusing is why I left some go.
djevans
Tennessee
Posted: 04/10/08 09:04am Link  |  Quote  |  Print  |  Notify Moderator
This site might help "graphically" demonstrate what's going on in these circuits.
Don . . . near 36.171N 086.784W, TN near here
WA4ZFN
2003 Fleetwood Revolution 40C - Saturn VUE
350hp Cummins ISC
- - - P i c t u r e s - - -
I'm confused, WAIT! Maybe I'm not!
hemi-kz
Eastern PA
Posted: 04/10/08 09:18am Link  |  Quote  |  Print  |  Notify Moderator
You're right. I stand corrected.
A 4-way could be (and probably is) made by cross strapping the switched poles of a DPDT internally.
