kdkrause
Redcliff AB Canada
We are awaiting the arrival of our Trail Lite TL30BH. One of the things we requested when we ordered the trailer was to have one of those larger folding assist handles installed instead of the small one the trailer came with. Apparently they couldn't do this at the factory so the dealer is going to add it. It sounds like they plan on leaving the small handle in place and then installing the large handle overtop of the small one. Does this make sense? Will it look silly? Ideally I would like the small handle removed but I am not sure what to do with the holes left behind.
ethomps1
Dearborn Heights, MI
I was just at a dealership and many of the small handles were left in place. I did notice them, but it was more of a "Great, they added the assist handle". It didn't look silly to me.
Liz (the Bad Liz)
2004 Amerilite 21MB
2005 Ford Exploder Sports Trac
3 small dogs
1 big husband
The Bad Liz
Camper pictures
kearlms
Rexburg, ID
My B-I-L has both the small handle and larger assist handle on his TT. It does not look bad. Just think you will have two handles now.
sclark
Minnesota
I have both on my rig as well. We use both from time to time. Just leave it. Good luck.
2004.5 Dodge Cummins
2007 Wildcat 32QBBS
Pair of Honda 2000 Watt generators
Dixonmatco
Santa Rosa, California
Two handles would work and look better than two holes. Besides, when the big one is folded back, the other one is still there to use.
2000 Chevy Silverado 1500
2005 Komfort Trailblazer T23S
Honda EU2000I
RamTX
Cypress, Tx.
It may look silly but that is how I installed mine. I have also seen a number of other trailers with the handles installed like that as others have stated. I find that the smaller handle is better for pulling while going up the steps and the folding assist handle better for going down the steps where you just need to steady yourself.
2005 Dodge 2500 CTD ShortBed Quad Cab
08 Jayco Eagle Superlite 31.5FBHS
Line X
Superglide Hitch
Prodigy Brake Controller
The Dude Dad
Simi Valley, CA
I left our little one there too. It really doesn't look that bad, and if you need it, it's still there. The large assist handle was super easy to install, took less than 10 minutes. You could always have the dealer just give it to you and install it yourself.
2007 Thor Wave 26RLS
2004 Chevy 2500HD Gas Hog
DW Michelle, Son Tyler, Daughter Kaitlyn, and one on the way!
xfire82
kannapolis nc
Installed my assist handle over the lil factory one also. Oem handle is white, so doesnt stick out in a crowd. You will find a definet advantage to have both.
With a badly broken ankle I could not have gotten in or out without having both.
Take 10 mins, drill the 4 holes and mount it yourself. Dealer labor will probably tripple your investment.
"Retirement Home" 2004 Coachman Cascade DLX 26RBS
2001 Expeditions EB
