MrD
Washington
Hi all,
I just went out last weekend on my first camping trip of '08. and it occured to me that with this new digital (DTV) signal coming in FEB '09 I may have to get a converter for my trailer. I have been ignoring the information about this since I have cable at home, but I didn't think about the trailer until this weekend. I know a lot of you have dishes, but those that don't, have you thought about what you are going to do?
Mike
Mike and Char
2002 Chev 2500HD CC SB 6.0 4.10 4x4
2002 Arctic Fox 245n
Dennis Bham
Alabama
Mike,
If you will go to this site: www.dtv2009.gov
and sign up, the federal government will mail you two $40.00 certificates that can be used at local stores like Walmart, etc. to purchase 2 DTV converter boxes that can be used with your old analog TVs for digital over the air reception. The manufacturers are building converters that will cost as little as $40.00
Dennis
'08 Chevy 2500HD Duramax 4x4, Crew Cab, Std Bed e/w 18K Superglide
'08 Cougar 292RKS, e/w 16" Sendel wheels & BFG Commercial TA tires
PressurePro TPMS
sclark
Minnesota
I will be getting a converter for the RV. Will not be doing anything to the antenna, as it will work just fine with the digital signals. Good luck.
2004.5 Dodge Cummins
2007 Wildcat 32QBBS
Pair of Honda 2000 Watt generators
Peg Leg
Anderson, IN
I just finished bolting down an HDTV so I don't have to move it when traveling. The antenna and amplifier work just fine on HD.
I have a LG for the TT and a JVC in the house. The LG will recieve signals that the JVC won't, this is with both hooked to the same antenna that's 30' high and no amplifier.
KA9ATV
K2500 7.4 3.73
Michelin 245/70R19.5 XDS2 on Vision Type 81's
31' Dutchmen
Yamaha EF3000iSE
retired gadgetman
Gaffer
Wildwood, MO
I've been looking at this issue since early Janurary and I'll share what I've found. I applied on 1/13/08 on-line and just recieved the coupons (they look like credit cards) on 4/8/08. Second, they're only good for 90 days from the date of printing and by the time you get them you'll only have about 75 days left to use them. Third, the best features and hardware improvments only are available on very few models out of almost 70 brands and product lines. The best features include: analog pass through when powered off, s-video output, smart antenna, and a signal strength meter. I won't try and explain all those features as to value but they are the things most of us will want. Out of the almost 70 converter boxes listed on the Gov. web site more than half aren't even being built yet and might not even be available until late this year. At this time no big box retailer has any models with all the desirable features I listed above. The best models I've found are from an unheard of brand; Max Media. Their current model #MMDTVB03 (it may have analog pass through when off but has all the other features)is almost impossible to find at this time and a new model that won't be out until June the Max Media #MMDTVB02 which has all the features. The Philco TB100HH9 and the better Philco TB150HH9 have most of the features. Others that (I think) are not yet in production but could have most or all features are the Echostar TR-40 and the Digital Stream DX8700. If any of you find any of these models available let us all know.
97 F-350 2WD Supercab Dually 460 V8 w/4.10 ltd slip, Gibson cat-back, Banks Ram Air w/K&N, Banks Trans Comand, front/rear Air-Lift bags, Bilsteins, MSD coil/wires/cap/rotor, Autolite 2x platinum plugs, PullRite Super 5th
06 Carriage Cameo LXI F30RLS
randy&shereen
Jackson, MI
Just got a "Insignia" which is the Best Buy house brand for $59.95 plus tax less the $40.00 coupon. Can't believe that it made my antenna picture look as good or better than my DirecTV picture. Don't know about if analog signal will pass thru but will try it later. Randy
2004 GMC Sierra 2500HD SLT CREW CAB LONG BOX (7380#)
8.1 Big block Gas/Allison 4:10 4x4
2004 Newmar Kountry Star 34 BLWB 3 Slides (15620#)
Pin Wt 2560# (16.3%) Total combination Wt=23,000#
Roy T
Dodge City, Kansas
My RV is new enough I don't have to worry about it. At least that will free up some money for something else.
wild acres
Brandemburg, Ky 40108
The new RV View from camping world, has them for $59.99. Don't know if they are any good, or if you can apply the coupons toward them. Hope this helps. John
John Ret USArmy
Linda waiting
Jake (soft haired Wheaten terrier)
02 Ford F-250 7.3L PSD 4 x 4
05 Cardinal WBLX 29'
DutchmenSport
Indiana
... or just buy a new television that is digital ready!
DutchmenSport
2005 Chevy Silverado 3500 Dually Duramax 6.6L V8 Turbo
Century Truck Cap Commercial /Toolboxes
Northeast Outfitters Canoe
2006 Keystone Springdale Model 263DBL
Weight 4985, Carrying Capacity 2575, Hitch 560, Length 30'
Width 8', Height 10' 6"
Traveling Texans
College Station, Texas
I may be out of place here but I understand that the change over will not effect Dish, Direct, or Cable users. It is only those that are working off antennas. is that correct?
2007 Chevy 2500HDCC D/A SWB
2006 Outback Sydney 28FRLS
