Rhinojoe
Inland Empire
This is camping guys, who needs a TV?
geeman53
springfield,ohio
Traveling Texans wrote: I may be out of place here but I understand that the change over will not effect Dish, Direct, or Cable users. It is only those that are working off antennas. is that correct?
That is correct.
Gman
Ford superduty, Bedsaver, Heartland Sundance-"Buckeye Express"
2 DA WDS
Sherman, Il, USA
geeman53 wrote: Traveling Texans wrote: I may be out of place here but I understand that the change over will not effect Dish, Direct, or Cable users. It is only those that are working off antennas. is that correct?
That is correct.
Gman
I read something the other day. That the digital change over will affect some cable customers. If you google that sentence there are a lot of articles about it.
Happy Trails
Tom & Cheryl
2001 Chevy Silverado 3500 dually 8.1 Road Tamer air suspension
2005 Mobile Suites RE3 S.O.I.T.C. Charter Member #1646 Prodigy
TomTom GPS
HUTCH45
NORCAL
Rhinojoe wrote: This is camping guys, who needs a TV?
"HUTCH"
'07 SILVERADO 3500HD 'CLASSIC' DRW - CC - 4 X 4
'07 NEW HORIZONS 35' 5th.Wheel 'MotoMover'
'06 HONDA 106hp.VTX1800 w/'HANNIGAN' Sidecar
"PRIMO" The Boxer
crash1068
Louisiana
We NEED a TV I work from my camper a good bit and we go to see family a lot with the camper. Hence, we're not always in the most entertaining place and with the kids, if it's raining, or mosquito infested New Orleans in the summer, you better have some night time fun also.
How do you identify if your TV needs it? I was under the impression that pretty much any flat panel tv with a tuner would be fine?
2008 Sierra 325RGT w/02 Chevy Crew Cab Dually
- My Super Wife
- 5yr Old Girl"Boo"
- 3yr Old Son "My Lil Buddy"
- 7 Month Old Girl "Sweet Pea"
& more stuff than can possibly fit in our camper!
40 Acres in the National Forest of Louisiana ="Bliss"
sirdrakejr
Las Vegas, Nevada
Moved from 5th wheels to technology corner.
Frank
RV.net blog
For those of you looking for expert advice, here ya go!
Frank
Wherever I happen to park
The Insignia will not pass analog. In a one converter per TV install (Which I recommend) you put a splitter in the antenna lead to the TV, split the signal so analog still goes to the TV (Actually everything does but the TV ignores digital) and then you send digital (Likewise everything but the converter ignores analog) to the converter.. Use the A/V cables (included with the converter) to feed an A/V input on the TV if you have one
If not then put a switch (Standard A/B or Game/Antenna or Cable/Antenna switch after the converter
The first splitter line (Direct to tv) goes instead to the ANTENNA or "A" contact on the switch.. The converter to the other one and the common lead to the TV Now the switch works to select Digital or Analog
The only problem I have with the Insignia is that I have to unplug it every week or it locks up on me... Don't know why
sctusa
Carrabelle, Fl.
Fulltimer here so I enjoy TV at times!
But thanks for reminding us.
Scott
2005 Dodge 3500 4X2 HO CTD Dually 6 Speed
2005 Springdale 266RELL GL
Reese HP Dual Cam
Prodigy BC
2 Honda EU2000i's
2 Lifeline 31 Series AGM 12V RV Batts
2006 Harley XL1200R
SP 2610 GPS
26" Samsung LCD HD TV
Ultralife
West Coast, USA
gman53 and travelin texan. yes, no, and sort of.
At this moment I am receiving Very strong digital signals/pictures on my high definition tv thru the roof antenna. If you can't get local channels 7.1, 7.2, 13, 13.1, 13.2, 13.3, etc, your not getting digital signals. The tv is a 26" LCD HD Samsung. I will not need a converter box to receive digital signals. If you have a HD ready tv attach your rg-6 coax from the roof antenna to the "air" port on the back, go thru menu set-up to establish all the parameters, kick back and enjoy.
If you do not have hd ready tvs, and I do have three of them,, yes you will need a converter box.
Where you are is where your at!
2002 Beaver Monterey 38' DP 330HP Cat
2002 New Beetle "Silver Bullet" Turbo Sport (Manual 5-speed)
Blue OX tow bar and base plate
Who says AZ summers are hot???
Don and Pat
