RV.Net Open Roads Forum: Travel Trailers: towing with a f-150
 > towing with a f-150
arobinson
mississippi
Posted: 04/10/08 02:29pm Link  |  Quote  |  Print  |  Notify Moderator
We are considering puchasing a rockwood 1808 mini lite by forest river. We would be towing with an f-150 ford truck. Has anyone with this model travel trailer had any problems towing? Also, any problems with the quality of this trailer?
Wampus
Virginia Beach, VA
Posted: 04/10/08 02:45pm Link  |  Quote  |  Print  |  Notify Moderator
It is best to refer your truck to the the Ford Truck Towing Guide that you should be able to find online with any search engine. If you tell us the year, engine, body style(Extended cab, longbed), and the rear differential gear ration, some of the members here may be able to tell you from their experiences. Some of this information should also be listed on a name plate or decal inside the driver side door jamb on most Ford Trucks. Also, the weight of the trailer can be found in the same fashion also. Good Luck
Bill and Donna D.
2008 Wildwood 26TBSS
2006 Ford F250 XLT EC, 5.4 Ltr, 3.73 LS, Torqshift, & Tow Command
jayco322
canton, ohio
Posted: 04/10/08 02:46pm Link  |  Quote  |  Print  |  Notify Moderator
We had a Rockwood 8314ss which is bigger and I pulled with a 04 F-150. It did just fine. You will have no problem pulling that. We traded in our Rockwood after 1 season for a Jayco. We had a lot of problems with the Rockwood. That does not mean they are all bad though. It is all what you like.
bluwtr49
Green Valley, AZ
Posted: 04/10/08 03:22pm Link  |  Quote  |  Print  |  Notify Moderator
Isn't the 1808 only 18' with a GVWR of about 4600 lbs or so? I would think the F-150 should tow close 29" and 10,000 lbs with all the tow goodies.....you should be in fine shape.
Dick
2008 Toyota Tundra Crew Max Limited TRD
2009 Cougar 268 RLS ~8400 lbs road wt
Equal-i-zer 12,000 lb hitch, Prodigy BC.
2006 Jeep Liberty Turbo Diesel.....TV in Training
2005 Jeep GC 5.7 HEMI,(retired)
2005 Jayco Jay Feather 25Z, 4" lift (Retired)
Rumtan
Alberta
Posted: 04/10/08 04:16pm Link  |  Quote  |  Print  |  Notify Moderator
What size motor does your truck have? What is the weight of the TT?
2002 Palomino 22'
2002 Chev Silverado V8
Fish-O-holic
Terryallan
NC
Posted: 04/10/08 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
Yes you will need to know what motor, and rear gear you have. If it is a V6. you may not be able to tow it.
Terry & Shay
Pioneer 23T6
04 F150, 5.4, Lariat SuperCab
Lazy Campers
NC
Hornet28BHDS
Parker, PA
Posted: 04/10/08 06:07pm Link  |  Quote  |  Print  |  Notify Moderator
We need a little bit more info on your F150.
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
SemperFiCop
Posted: 04/10/08 06:15pm Link  |  Quote  |  Print  |  Notify Moderator
True,
but if he has a 2002 V6 with the 3.08 rear axle
he will only be able to tow no more than
2,000 pounds...
