marbilupton
north carolina
I just got back from a short trip (400) miles and when I checked my coolant today there was less than 1/3 in the reservoir. Before I left to go on the trip, I had topped it off, because it was almost empty, so I know that it was full when I left. Any thoughts on why this could be?
Retired Navy, 39 Years
2005 Winnebago Voyage 35D
2006 Honda Crv
Blue OX Alexus Tow Bar
Brake Buddy
wolfe10
What chassis/engine?
Brett Wolfe
1993 Foretravel 36' U-240
Cat 3116, Allison 3060
Caterpillar RV Engine Owner's Club: www.catrvclub.org
marbilupton
north carolina
Sorry, Ford V-10
John Wayne
Long Beach, Ca
Check the hose clamps they have been famous for rusting through and leaking under pressure replace with the worm type in SS.
John & Carol
01 31'Sea View single slide, F53 V-10
96 Toyota 4-Runner auto 4x4 (Remco, M&G brake system)
KF6HCH
jenks60
MS. coast
You are not supposed to "top off", there should be marks for "cold" and "hot".
If you fill it up, then it blows out the overflow pipe and when it cools it will be down considerably
If it is 1/3 full, the radiator is full.
It could also have a crack in the resevoir, like mine does. It will only leak when pressure is built up, makes it hard to find the leak.
jenks, fulltiming with the DW.
92 Southwind P3(32) 33 ft.
99 Saturn SL2
Rallys attended-TX 2, LA 2, MS 1, AL 2
MA. 1 drop in for visit.
wolfe10
John Wayne wrote: Check the hose clamps they have been famous for rusting through and leaking under pressure replace with the worm type in SS.
YUP, been a known problem for years.
marbilupton
north carolina
jenks60 wrote: You are not supposed to "top off", there should be marks for "cold" and "hot".
Yes, what I should have said was, I filled it up to the fill level. " Top off" does sound like I filled it up to the Cap.
buchrob
Stanstead QC
Now that we know that all of the mfgr recommendations are not quite gospel, my heart also goes out to all the diesel pusher owners who fill with oil to the top mark and then panic when then the level has gone down to the minimum after only a few hundred miles, assuming major engine problems when those rigs are designed to blow by any escess.
'99 Glendale Royal Expedition 24' Class C
2003 Subaru WRX wagon as toad.
justimagination
Monroe, Georgia
I would check your radiator cap 1st, with the engine cold. Check the rubber seal really good. Good luck.
1997 Fleetwood Southwind 37Y / Ford 460 / Power Platform / Tag Axle
Our Crew: (1)Yorkie, Twin Japanese Chins, Toy Poodle, Chihuahua, and last, but not least, their "MOM", my co-pilot and wife.
Buick Regal
Ford Taurus
Proudly served, USAF 1959-1963
Wizard 1946
Georgia
On my 2002 V-10, the level stays at about an inch above the bottom of the overflow tank. Over the years I have filled to the cold full level and after a trip it was back down to the inch mark. When the engine is hot it will rise to about 2 inches. Been like this for years and never ran hot. If anyone finds anything different, please let us know.
Wizard
32' 2002 Brave, Ford V-10
2006 Explorer 4X4
Nothing I've got to do and all day to do it
