RV.Net Open Roads Forum: Class A Motorhomes: Coolant Loss
 > Coolant Loss
Love retirement
Harrison, Ohio
Posted: 04/11/08 08:24am Link  |  Quote  |  Print  |  Notify Moderator
Mine was the upper clamp on the lower radiator hose. Took some time before it leaked enough to be evident. 2002 V10.
sawdust_128
NC
Posted: 04/11/08 08:28am Link  |  Quote  |  Print  |  Notify Moderator
Could be simple. If resevoir got low, air may have gotten in to the hoses. After you filled to mark and ran engine, air was displaced and now system is filled but resevoir isn't. Fill and run again before you get concerned too much. This is the kind of stuff that should be checked at every fill up.
Regards and Goog Luck.
P.S. Sometimes a squeeze of the top radiator hose will eject air. You can usually hear it bubbling about.
Sawdust_128
jtweider
Port Angeles, WA
Posted: 04/11/08 11:15am Link  |  Quote  |  Print  |  Notify Moderator
I had to replace mine yesterday on an 06. I always had a small loss could not find it then yesterday really started leaking. It was the lower hose on the block. The clamp was broken from day one I guess. I inspected the others and they appear fine. I'm keeping spares in the coach though. best of luck Jerry.
 > Coolant Loss
