RV.Net Open Roads Forum: Travel Trailers: adjusting the prodigy brake controler Please HELP!!!!
 > adjusting the prodigy brake controler Please HELP!!!!
LovemyDurango
Dieppe NB Canada
Posted: 04/10/08 03:59pm Link  |  Quote  |  Print  |  Notify Moderator
Hi everybody
I bought the brake control under you guys advisement and it seems to be very smooth but I don't know if I'm adjusting it properly.
I have a 6500lbs trailer and I have set at 6.3 and I turned the little wheel until the wheels lock up at 25 miles an hour using the lever at the bottom,then backed it a little. Is that right. When I brake it shows on the digital screen variable # up to about 3.4.
I think that I'm using my vehicle brakes a lot more than my trailer. I just want to make sure that I'm set up properly. I feel like I should increase the intensity i.e. the wheel or the digital # higher but I don't know. I feel a little stupid with this one. I was use to my old analog basic unit but maybe I'm just making it more than it is. Help!!!
Thanks
youth4him
Belgrade, MT
Posted: 04/10/08 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
You seem to be on track. Braking is somewhat a matter of preference. I prefer to feel the little tug from the trailer when I'm braking at slow speeds, telling my the trailer brakes are doing more of the work. Some don't like that.
You will get a better feel for it as you drive around town, if you're hitting your head on the steering wheel, it's adjusted too high. If you're not feeling anything from the trailer brakes as you are coming to a slow stop, it's adjusted too low. Not all that scientific, I know, but it's worked for me now for years.
KD
Trip of a Lifetime Blog - 10372 Miles, 88 Days, 4 Humans, 1 Mini Daschund...FUN!
Wildwood LE 23BH
2003 Chevy Suburban 4x4 Z71 5.3L 3.73
automap2002
West Jordan, Utah
Posted: 04/10/08 05:09pm Link  |  Quote  |  Print  |  Notify Moderator
Do you have it set on one of the boost modes? Wit the trailer weight I would try it wit no boost and if you don't feel comfortable with that just take it up to boost 1 and see if that helps if not take it up higher to boost 2.
hemi-kz
Eastern PA
Posted: 04/10/08 05:16pm Link  |  Quote  |  Print  |  Notify Moderator
It sounds like you have the voltage set correctly. So now you can tweek it to your own comfort. Don't worry too much, it's not an exact science! Have you experimented with the boost setting? You won't feel much from the trailer brakes with boost set to off, because the TV brakes will always be leading (applying first). Boost lets the trailer brakes lead the TV a little bit so you feel them working. For my 7000 pound trailer I like the boost on 2 in the hills, but I find the extra tugging is annoying on the flats so I set it to 1.
2007 KZ 22 Sportster Hybrid Toy Hauler
2003 Dodge Ram 2500 4x4 Hemi Quad Cab Short Bed
1990 Harley Electra Glide Classic
2005 Harley Sportster 883L
LovemyDurango
Dieppe NB Canada
Posted: 04/10/08 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
Where is the boost setting. I only noticed the wheel on the left and the button on the right. Is there a different setting.
Terryallan
NC
Posted: 04/10/08 05:58pm Link  |  Quote  |  Print  |  Notify Moderator
It's the button. Sets the boost. But in fact. If it is set correctly. You won't feel it working. It won't jerk, It won't grab. It is seemless. If you don't feel the TT pushing you. You are good to go.
If as you say. The TT brakes lock at 25 mph when you push the lever. and yopu backed off a little, To where they almost lock. It's right.
as for the numbers you see while braking. The Prodigy will only send what is needed under the type of braking even you are having. If you have to brakes real hard. Higher numbers will show up. The harder the higher. It depends on how far you swing that electronic pendulem.
Terry & Shay
Pioneer 23T6
04 F150, 5.4, Lariat SuperCab
Lazy Campers
NC
Trickewon
Lebanon, Pa
Posted: 04/10/08 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
Sound like you have it right I love mine, one thing that might help is the brakes on trailer could need adjusted a little tighter
Pappy, Two Grandkids & Their Dad Camping The Way It Was Meant To Be
F150 SuperCrew 5.4 V8 Wildwood LE 27BHSS
cjoseph
WV
Posted: 04/10/08 07:43pm Link  |  Quote  |  Print  |  Notify Moderator
Tune as you said with the wheel. Then select the boost level you want.
The digital readout should display b1, b2, b3 as you hit the boost button. I use b2 on the fast road(7k), b1 on the slow road.
Chuck, Heidi, Jessica, Nicholas & Tan Puppy
2008 3/4-ton Yukon XL, Flagstaff 831BHSS
Equalizer Hitch and Prodigy
92DakotaHD
Indiana
On my dakota I had mine set so it pretty much stopped like normal under normal conditions. No real pull, no push, just stopped like nothing was behind me. Great controller, just tweak on it while on your next trip, you'll find your setting.
1992 Dakota 2WD 5.9L V8 (NOT Stock)
Headers, FMS Injectors, Ported TB, MP PCM (not good for towing),
2005 Chevy Tahoe Z71- Bermuda Blue, A/T Revo 265/70 "E"
Prodigy Controller
08 Passport 24RB, YAY SPACE!
Gone Racing!
A newbie, any tips please share!
Earl E
Klamath Falls, Oregon
Posted: 04/11/08 10:36pm Link  |  Quote  |  Print  |  Notify Moderator
I use b2 all the time. Never need to readjust it with a 7000# gross weight trailer.
2008 Keystone Springdale 252
2004 Chevy Silverado, 5.3 L V8
Prodigy brake control and Equal-i-zer
Retired and traveling all we can!
