I have a 2001 F-250 with a 6" lift and I am getting ready to buy a equalizer 14000/1400 hitch and I am wondering what size shank to go with. a 6" drop or a 9". I am towing a sandpiper 31sp Th. I hate to order the wrong one. Thank you
You'll have to measure to be sure. I have a stock Dodge 3/4 ton 4x4 and use a 6" drop for most towing use. However, I have pulled an enclosed trailer that required only a 4" drop and a specialty trailer that needed only a 2" drop.
Again, measure to be sure. Remember that your rear suspension will likely sag under the load.
2006 Dodge Ram Quad Cab, HO Cummins, 4x4
2000 Sunnybrook 26FK
2006 Stock Trailer
1996 Car Hauler
I had a 31sp, great rig, very stout. Know that its heavier than stated on the cabinet sticker. If I recall, my ball was even with the receiver on the distribution set-up, and that was a stock height f250 4wd. Truck and trailer leveled out perfect. Dealer had set the equipment up at trailer pick-up, they nailed it. My guess would now be, your ball should be 6" below the receiver, huh ?
paul
Sig Line was here.
