RV.Net Open Roads Forum: Tech Issues: Official word: eu2000i runs air conditioner
 > Official word: eu2000i runs air conditioner
Matthew_B
The boonies near Dallas, Oregon
Posted: 04/11/08 12:33am Link  |  Quote  |  Print  |  Notify Moderator
hershey wrote:
It ain't big enough to power an AC at any elevation for any length of time.
That sort of depends on the AC size. 9,000 BTU ACs and most 11,000 BTU ACs run just fine on one eu2000i.
MI Director
Michigan
Posted: 04/11/08 06:28am Link  |  Quote  |  Print  |  Notify Moderator
If you look at the ad the bottom 1/3 shows 2 in Parallel and a discount on the kit. I personnel know that at the Camping World store here in MI they tell people that one 2000 may not start the A/C and is over loaded running an A/C for long periods of time. Start load versa running load.
The problem is no one just runs the A/C alone. You have a converter and possibly an inverter that is on when plugged into the power cord. Most converters with chargers can pull up to 1000 watts so there goes over half of the available watts.
Scrib
Maplewood
Posted: 04/11/08 06:44am Link  |  Quote  |  Print  |  Notify Moderator
Wayne Dohnal wrote:
...you are assuming the Honda EU2000i is a 2,000W generator.
I'm not assuming anything, just repeating what the ad says. This is a major dealer and the ad is on shiny paper, so it must be correct. Try to find the magazine and see for yourself. This is professional work.
Doh! I read that completely wrong - sorry.
Chris Bryant
DeLand, Florida, USA
Posted: 04/11/08 07:05am Link  |  Quote  |  Print  |  Notify Moderator
Heck- I also read that I can buy a cologne that makes me irresistible to women .
-- Chris Bryant
My RV Service Blog
The RV.net Blog
jnharley
Virginia Beach, Virginia
Posted: 04/11/08 09:05am Link  |  Quote  |  Print  |  Notify Moderator
EU 2000 runs our 15,000 btu a/c, however, we are at sea level.
2004.5 Silver Dodge diesel dually
2004 Sunnybrook 391 SUT Toy Hauler
1999 Harley Road King
jaycocamper62301
Illinois
Posted: 04/11/08 09:56am Link  |  Quote  |  Print  |  Notify Moderator
My Axe body wash says use may result in "unrelenting female attention" ???????
2008 Ford F250 Crew Cab Short Bed 6.4 Lariat Dark Stone & Tan
2008 Jayco 32 BHDS G2
Dixonmatco
Santa Rosa, California
Posted: 04/11/08 10:03am Link  |  Quote  |  Print  |  Notify Moderator
Actually mine will run my 13.5 when necessary, but I rarely need A/C.
2000 Chevy Silverado 1500
2005 Komfort Trailblazer T23S
Honda EU2000I
kmfvfr
Las Vegas
Posted: 04/11/08 10:28am Link  |  Quote  |  Print  |  Notify Moderator
I have actually disconnected my house from Nevada Power because my Yamaha 2400 will run the entire thing....including BOTH A/C units in the heat of summer!!
2008 Pacific Coachworks Tango 276 RBS
2007 Toyota Tundra TRD 5.7L
Prodigy Brake Controller
Yamaha EF2400iS Generator
Yamaha FJR1300
jay2003
San Joaquin Valley, California
Posted: 04/11/08 11:07am Link  |  Quote  |  Print  |  Notify Moderator
It's only correct from a marketing perspecive in that they can print it without legal recourse because there is at least one manufacture of an A/C that falls within those specs and will work according to advertized. Yes there are laws about truth in advertising so yes what's printed is true BUT to say that any particular generator will run ALL 13.5 BTU A/C units isn't correct. With the specs the add says then yes it will work. Mine works just fine with fridge on propane and the battery charging turned off. I also posted in another thread about the newer Coleman A/C units that are up to 3-4amps less in electrical usage than "older" models.
Funny I saw the same ad after I started my other thread and was waiting to see if someone would make a blanket statement.
05 Toyota Tacoma DC 4x4 SB Off-Road Package w/Tow 128" WB
2005 KZ Jag 24JB*Newer Model Floorplans Slightly Different
Prodigy Brake, WD hitch, friction sway
Garmin GPSMAP 60CSx
Honda EU2000i Generator
Me.. the wife, the 5 year old, and the 2 year old
Wherever I happen to park
Posted: 04/11/08 11:58am Link  |  Quote  |  Print  |  Notify Moderator
One thing about running right close to the edge
In another thread we were discussion how to tell if a sealed air conditioner was low on freon... Turns out you measure temperature, humidity and current while it's running.
As the outside temperature goes up... So does the current (and thus wattage) so if you are running "on the edge" when you need it the most (100+) it may well fail.
