RV.Net Open Roads Forum: Tech Issues: Leave em open or leave em closed????
 > Leave em open or leave em closed????
Cool Canuck
Winnipeg, MB, Canada
Posted: 04/10/08 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
OK, I park some place warm every winter. This means a month or two in one spot. I leave my black tank closed, however I leave my gray tanks open. I just got called clueless for this act. Am I in the minority?? Do you leave your gray tanks open for an extended stay or do you close them??
00 Jayco Eagle 313 5th
01 F250 PSD S/C S/B
sclark
Minnesota
Posted: 04/10/08 06:35pm Link  |  Quote  |  Print  |  Notify Moderator
I leave the tanks closed until I am ready to empty. I use the gray to flush out the sewer hose. After dumping the black tank, I add a couple of gallons of water back in the tank. Good luck.
2004.5 Dodge Cummins
2007 Wildcat 32QBBS
Pair of Honda 2000 Watt generators
skipnchar
Topeka Kansas USA
Posted: 04/10/08 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
I leave either my galley tank OR my gray tank open all the time. The only tank that NEEDS to be kept closed is the black tank. If you flush a lot of garbadge down the galley tank it probably would help to leave it closed also so it will flush solids out when you dump but we're pretty careful about not allowing solids down the drain. If you can plan ahead enough to close the gray for a day or two prior to leaving so you have some flush water to help clean up the hose it can be beneficial.
Maintcpo
Central California
While there is nothing wrong with your current procedure, I would close the grey the day before or 2 maybe to get some backup to flush the stinky stuff out of the hose. This may not do much, but will help make sure you dont have anything resting in the hose. Just a thought.
Dan, Ret Navy CPO
Minnie The Wife Extraordinare
Chris Our Son the Genius
3 Dogs 1 Dumb , 1 Fat and Stubborn, and 1 new and Adorable
2005 Jazz 2550RL 5er
2003 Dodge Quad Cab Long Bed Cummins 6 shooter
Krusty
Calgary, Alberta,Canada
I leave mine closed. If the tank is getting full and I want to take a shower, I may open it up partially, but generally not until tank is full.
Krusty
92 F-250 4x4 460 5spd 4.10LS Prodigy
97 Rustler RT190
EU2000i
Garmin
The Texan
Summer: A Cool Climate Winter: A Warm Climate
Posted: 04/10/08 06:44pm Link  |  Quote  |  Print  |  Notify Moderator
I have had a RV with holding tanks since 1972 and do exactly what you do, dump black when full and leave grey valve open all the time while parked. I use a tornado system to flush the black tank, so no need to hold the grey for flushing. I have never had a problem with the grey or black tank, in the 36 years I have been doing it this way.
Bob & Betsy - USN Ret'd '78 & FL LEO Ret'd '03
FMCA #F203528
'05 HR Endeavor, 40PRQ w/400 Cummins - With -'05 GMC Sierra LT, CC Z-71, the pusher
'07 Arctic Cat 500A & Wilderness Kayak, riding in the pusher -
Our Current Location
DutchmenSport
Indiana
Posted: 04/10/08 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
If I have full hook-up, I dump when the gray is full (and do the black also, even if it is not full). Why? Both tanks drain into the same outlet. With a third valve attached, I drain all I can out of the black, then close off the 3rd valve. Then open the gray and let it back flush into the black for a few seconds. Then close off the gray and open the 3rd again to flush the black until empty. I repeat back flushing the gray into the black until there's virtually nothing left in the gray. This REALLY cleans out the black, forcing water in and then out. Doing this, there's never any need for chemicals. Soapy dishwater and bath water back flushes into the gray, keeping it nice and CLEAN! That' just the way I do it. Might be a lot of work for some people, but I don't mind. It works!
DutchmenSport
2005 Chevy Silverado 3500 Dually Duramax 6.6L V8 Turbo
Century Truck Cap Commercial /Toolboxes
Northeast Outfitters Canoe
2006 Keystone Springdale Model 263DBL
Weight 4985, Carrying Capacity 2575, Hitch 560, Length 30'
Width 8', Height 10' 6"
robatthelake
Vancouver Island
Posted: 04/10/08 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
The danger of leaving the Grey open is that Critters can crawl up it and cause grief by Dying inside or laying eggs and feces! Where We often Camp there are sewer Iguanas as well as snakes!
Personally I just Dump when ever it needs to be done and keep the Hose Off the Ground!
Rob & Jean 90 Southwind John Deere/Oshkosh/Freightliner Class A Ford 460/ Toad 92 Tracker 2 wd 5sp Convert Still running Great!
" Everything in it"Still" Works"
othertonka
Stockton, CA
Posted: 04/10/08 08:03pm Link  |  Quote  |  Print  |  Notify Moderator
Since you asked for opinions, I leave both valves closed until it is time to dump. That way the gray tank does not collect food particles in the bottom of the tank because there was not enough water to flush them out. And the gray tank is not exposed to the sewer smells from the park sewer coming back up the hose because the valve is Closed. I have done it this way for over 30 years and it works for me. Which way is right? Only you can answer that question after being armed with all of the opinions offered. If you want to leave the valve open, do it, If you don't, don't do it.
Othertonka
2004 Southwind 32VS
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
MI Director
Michigan
Posted: 04/10/08 08:13pm Link  |  Quote  |  Print  |  Notify Moderator
Same as othertonka. If you have never seen a soap and particle built up in a gray water tank your in for a treat. Friend got a unit from a snowbird who left his gray valve open all winter down south every year and it had the worst odor out of the gray tank you've ever smelled. Went over with a pressure wand and opened the valve and started to flush the tank. I would say we washed out at almost a bucket full of hard white soap scum with black chucks mixed in. The smell was worst than any black water tank.
