callen06
st.charles, mo
I am already needing new tires for my 06 WW Fk2100.
I am having trouble finding anything decent in the original size of 205/75r15. I wanted a tire a bit better than original in load capacity.
There just doesnt seem to be anything else available in this size besides the junk that it came with. For what it seems trailer tires are going to cost I would expect them to last more than 2 years.
what are some of you using out there ?
Kenneth
Washington, the state
The load capacity for any given size and Load Range is set by industry standard. In your size, you'll find Load Range C tires rated to 1820# @ 50 psi. If you have the room for bigger tires, you can use ST225/75R15 Load Range D tires rated to carry 2540# @ 65 psi.
Or try light truck tires. LT215/75R15 tires in Load Range D carry 2095# @ 65 psi, but require a wheel at least 5.5" wide. You'd want a highway rib tread or the smoothest all season tread you can find.
There are several brands of trailer tires that have good reports...Maxxis, TowMax, Goodyear Marathon, a few others.
Turbo Diesel Dude
Green Mountain, NC
Maxxis ST225 75R 15 load range E should fit OK
charles weidman
Walldo
Great Falls MT
Careful with LT tires, they not designed to handle the lateral force's that the tires are subject too when you turn a corner, especially with the weight of the toy haulers.
07 3500 GMC CC D/A Dually
07 3612 DS Raptor
06 VN 1600 Nomad
07 Can Am 800 Max
lincster
Mesa Az
Walldo wrote: Careful with LT tires, they not designed to handle the lateral force's that the tires are subject too when you turn a corner, especially with the weight of the toy haulers.
The tires I run can handle it.
Michelin XPS Ribs. Strongest E rated tire on the market.
Tire has steel cords in the sidewalls.
They are so stout, the tire guys at Discount had a hard time getting them mounted. They didn't want to flex.
Nothing wrong with a LT tire on a trailer.
Alot of big 5ers are coming with them standard now.
2006 F350 PSD CC 4X4 Dually w/Tow Boss package to pull 2006 LE3905
Lincsters Truck/Trailer
Lincsters Rail
HarleyMedic
Sour Lake, Texas
x2 on the Michelin XPS Rib. Not designed to handle the lateral force.....weight of toy haulers? BULL PUCKY!!! Slap you a set on there and you'll be ready to go.
Big Sexy and BonBon
2003 Dodge 2500 4x4 Laramie Cummins Auto, Edge EZ, AEM Brute Force, Timbrens, B&W.
2004 35SRV Victory Lane
1998 Harley Road King (Mine)
2003 Harley Road KIng (Hers)
2004 Yamaha Grizzly LE
Walldo
Great Falls MT
I never said that the XPS ribs were not strong enough, I am getting a set for my Raptor, The OP did not spec. the type of tire, just an LT tire.... The XPS are a commerical tire, the are made to handle the weight; unlike most LT tires.
callen06
st.charles, mo
Thanks Guys
I would like to run a larger tire with the E rating. The wheel well looks pretty tight. I'll have to do some measuring to see just how big I can go. I know right now pulling off the tire it has to push out the fender flare to get it out.
This has to be part of WW tire problems. They put a tire on a 7000lb trailer that to me is only good for a small trailer at most. I know they are C rated But I think they are just too small.
JIMNLIN
Big Cabin, OK
Walldo wrote: I never said that the XPS ribs were not strong enough, I am getting a set for my Raptor, The OP did not spec. the type of tire, just an LT tire.... The XPS are a commerical tire, the are made to handle the weight; unlike most LT tires.
on the contrary, LTs are a better design/engineered tire for side scrubbing issues/weight issues and most importantly speed rating. The only thing a trailer tire (ST) is better at is a P tire. Our higher GVWR trailers (even RVs) come with LTs. Even some RV manufactors offer them as a upgrade on their bigger units.
Jim
'03 2500 Dodge/Cummins HO 3.73 6 speed manual Jacobs
'97 Park Avanue 28' with two slides
