RV.Net Open Roads Forum: Class A Motorhomes: Strange Noise While Camping
 > Strange Noise While Camping
APP
Charlotte, NC
Posted: 04/10/08 11:52pm Link  |  Quote  |  Print  |  Notify Moderator
I am camping and today developed a strange noise while plugged into shore power. About every 20- 30 minutes I hear a click, then a short hum then a click again. I tried to isolate the issue with no luck. It almost sounds like it is coming from below the bathroom. The A/C's are off. I tried both electric and propane for the fridge and it did not make a difference. The water pump is off but I am wondering if it is having an issue.
Any ideas would be appreciated.
Thanks!
Al
Great Family
Some Dogs
Monaco LaPalma
fourfurz
Memphis
Posted: 04/11/08 12:08am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like your inverter is clicking on for some reason. They certainly hum when running. The click is probably a relay.
2007 Mountain Aire 4528
2006 CRV SE
Based in Memphis area
chiefcramer
USA Somewhere
Posted: 04/11/08 04:02am Link  |  Quote  |  Print  |  Notify Moderator
If you have an inverter/charger, it could be that your batteries are nearly fully charged now while you are plugged into shore power. The charger clicks on to charge, then clicks off?
Try opening the outside bay where your charger is and listen there to see if that is where the noise is coming from.
Dave & Kathy
2007 Monaco Knight 40PDQ towing 2003 Odyssey
Two cats - Kitty & Casey (18 & 15 years old)
Internet/Cell - Sprint - Sierra Wireless AirCard595U
Fulltime since October 2007
VintageRacer
Dundas, Ontario
Posted: 04/11/08 07:14am Link  |  Quote  |  Print  |  Notify Moderator
I had a similar sound as my Magnatek converter commenced to fail, fwiw.
Brian
2003 Dodge Ram 2500 Quad Cab, Hemi, 5 speed manual, 3.73 gears, Tow Beast hitch with 24" extension.
28 ft race car hauler, Lola T440 Formula Ford, NTM MK4 Sports Racer
2004 Travel Hawk 8' Truck Camper - Roll at 16K combined weight
DebDav
SE TX
Posted: 04/11/08 07:17am Link  |  Quote  |  Print  |  Notify Moderator
I also had a click and hum from my inverter. I reset the circuit breaker and solved the initial problem... The clicking returned and service replaced the inverter control board.
DebDav
93 Prevost H3-40 - converting
hemi-kz
Eastern PA
Posted: 04/11/08 09:07am Link  |  Quote  |  Print  |  Notify Moderator
Click-hum-click is the typical sound of an automatic thermal overload protection circuit breaker. For example, if an electric motor is stuck it draws very high current (hums). In a few seconds the breaker heats up and trips (click). 20-30 min later, the breaker cools off enough to reset (click), and the cycle starts again.
Just a thought, do you have an electric slide near the noise?
2007 KZ 22 Sportster Hybrid Toy Hauler
2003 Dodge Ram 2500 4x4 Hemi Quad Cab Short Bed
1990 Harley Electra Glide Classic
2005 Harley Sportster 883L
Keith M
Cle Elum
Posted: 04/11/08 09:54am Link  |  Quote  |  Print  |  Notify Moderator
If you know where your converter is then check that. Some of the converters are located below the refrigerator and are mounted upside down so you dont see them. The fan goes on periodically when its charging the batteries. Maybe you have some really bad batteries that dont hold a charge? A lot of RVers seldom here the converter fan because they are mounted outside the living area.
driveby
Vancouver BC Canada
Posted: 04/11/08 10:47am Link  |  Quote  |  Print  |  Notify Moderator
I vote converter turning a charge to the batts too.
2008 Itasca Sunova 35J Class A
1997 TJ Sahara, hard and soft tops and AC
Held together via Roadmaster Falcon 2 tow bar and stopped by US Gear Unified Brake system.
hohenwald48
Hohenwald, TN
Posted: 04/11/08 11:32am Link  |  Quote  |  Print  |  Notify Moderator
I don't think a LaPalma has a converter.
2001 Monaco Knight
2004 Dutchmen Dorado
1999 Jeep Wrangler
100% Solar Powered Home
When seconds count, the police are only minutes away.
DBro
Virginia Beach, VA
Posted: 04/11/08 12:02pm Link  |  Quote  |  Print  |  Notify Moderator
Another converter vote. Mine runs fairly often when hooked up to 120, even if only a few 12v. items are running. Don't know if that's good or bad, but its done it ever since I've had the coach. As I recall my old Flair did the same thing.
DBro
'03 Gulfstream Ultra Supreme 8336 F-53
'05 Saturn VUE toad, Marathon runner wife, and one big black dog
