RV.Net Open Roads Forum: Class A Motorhomes: Strange Noise While Camping
 > Strange Noise While Camping
Richard Pelletier
Chesapeake, VA, USA
Posted: 04/11/08 12:41pm Link  |  Quote  |  Print  |  Notify Moderator
From Monaco web site: "55 Amp Electronic 12V Power Converter" Both gas and diesel. Optional: 600 Watt Inverter
2005 40 ft Monco Knight PLQ 4 slides
2002 2500HD Crew Cab 8'bed 4X4
Duramax/Allison (A BIG TOAD)
Richard and Susan
BMWNUT
Rapid City, SD
Posted: 04/11/08 11:15pm Link  |  Quote  |  Print  |  Notify Moderator
On My 2002 Dolphin, the click and hum is coming from the refrigerator periodically. Listen closely to the refrigerator and I think you will find the source of the noise.
Richard in AZ
2002 Dolphin LX, Fulltiming
The Beave
Georgetown TX USA
Posted: 04/12/08 03:31pm Link  |  Quote  |  Print  |  Notify Moderator
Try turning off your water pump. If the noise goes away you have a small leak. The pump will cycle on for one pump (click) to bring the pressure back up.
Our pressure reducer at the fresh water fill had a small seam leak that I fixed with plumbers putty.
The Beave
30' 1997 Beaver Monterey
(The shortest DP we could find)
2005 Honda CR-V
Remco surge brake
MoRambler
Springfield, Missouri
Posted: 04/13/08 06:29am Link  |  Quote  |  Print  |  Notify Moderator
This winter, I had a relay go bad on our coach, and it was making the same sounds as yours. It would make a LOUD click, and hummmm. The relay was hooked to the inverter.
BTW, a previous poster said that a La Palma didn't have a converter, I'll bet it does UNLESS it has an inverter. Are inverters standard on La Palma's?
Larry & Ann w/Lucy the cocker
'00 Mountain Aire 350 Cummins/Spartan
Toad: '05 Jeep Liberty Ltd.
hr
Midwest
Posted: 04/13/08 07:04am Link  |  Quote  |  Print  |  Notify Moderator
I have a HOLIDAY RAMBLER and it has what they call a BIRD it is a box that controls the charging of the battery's and from what source,It has a large relay that will thump when the battery's are close to full charge when you are plugged in to shore power.
HR
T&A
SE Michigan
Posted: 04/13/08 08:07am Link  |  Quote  |  Print  |  Notify Moderator
My first thought, I've heard a similar clicking noise from my RV. Took quite a while to track it down to the Intellitec battery control center. Relays pull in at different times to determine whether to supply a charge to the house batteries or chassis battery. The hum, possibly caused by the additional load on the converter while charging the batteries. You could try checking the battery voltage to see whether it is jumping up, indicating charging, or dropping off, indicating a load. As stated in a previous post, a thermal breaker kicking out could produce a similar noise. Good luck...keep us posted if you learn anything new.
Terry
Terry & Amy
2004 Hurricane 30F on P32 Workhorse Chassis
2002 Jeep Grand Cherokee
