JKwock
S. Cal
Who has uneven front stabilizers and how do you even them up? I was thinking using 1/2 inch pieces of wood to make up the difference. That's the cheapest way. I saw a front stabilizer that spins and makes up the difference??? Any other suggestions?
Jason
hotbyte
Barnesville GA
I use a 1/2" piece of plywood I'll put under one leg if needed.
Our Web Albums
For pulling...2005 Chevy 2500HD LT D/A and 1998 Dodge Durango SLT 5.2L
To be pulled...2002 Glastron GX205 and 2005 Pilgrim 276BH-5SS 5'er
PackerBacker
Montreal, Quebec,Canada
I use a 5/8" piece of plywood which is the space between holes on the legs on my unit.
Eric
2009 Holiday Rambler Admiral 33SFS
Good Sam's - FQCC/Camping Quebec
My Photos
FOREVER FREE
Manchester, TN
Have used different thickness boards and very seldom was able to match the needed difference. Bought an adjustable link at CW all the guesswork is done. Simple to install, easy to use.
"BIG BOB" & DIANE:
Big Mac & Sarah (Retired Greyhounds)
2005 Prowler Regal AX6 365BSQS
2005 F-350 Lariat Crew Cab 4x4, DRW, 8'bed, 6.0 P/S Diesel,
Veterans, the reason we will always be "FOREVER FREE".
SUPPORT OUR TROOPS
Bill1374
Saratoga Springs, NY
Jason,
If it's just the site being out of level, then various thickness boards will even it up.
If you are saying the extensions are not even, it's not a complicated fix. Look at the top of the jacks. There will be a shaft between them at the gear box. On one end of the shaft, there will be either a bolt or pin. Remove that and adjust the lengths to equal, reinsert the pin and you're done.
Bill
2000 Hitchhiker II Rio Grande
2000 Dodge 3500 dually Cummins 5 speed Edge EZ and guages
troublemonster
Louisiana
I have an adjustable adaptor that fits in between the landing gear tube and the foot pad. I can screw the foot pad up or down to fine tune so that both pads touch the ground at the same time. I don't remember what its called but I got it from camping world. Blocks would work fine but this way you dont have to lug around any.
JKwock
S. Cal
Thanks for all the info.
Jason
blarsony
Boise, Idaho
I have the quick release pins that hold them in place. After getting as level with the truck as I can, I drop the legs and let the pins lock in by themselves, this elimiates the need to do anything other than level front to rear. I always put a plastic leveling block under the pads to keep them from sinking.
07 Dodge 2500, 6.7L CTD w/6spd auto. 05 Cougar 281EFS, Twin EU2000i's, 180w solar, (4)6v batteries, 3000w/6000w Vector inverter & More gadgets than should be allowed. Cant forget the Wife, 2-Kids (rock eaters), and the Mut...
Website with Pics - Our rig
