AZLetendre
Prescott Valley, AZ
I use Jeremy's 3rd picture on both my PUP and my Car Hauler, they work great. I clamp them tight inside the open hitch, then lock them. That prevents the hitch latch from engaging to tow and the clamp top will not allow it to remove. On my PUP, I also lock the latch open.
Brian, Kristi, Scott, and Kevin Letendre
1998 Toyota 4Runner
2001 Coleman Utah TT
Arizona Christian Wheeler's
AZLetendre Photo Bucket
gcandcc
Upstate NY
I've got a coupler lock too...I know it's mostly for show but agree with the "too much trouble theory. I'm going to employ BOC method also.
As back up I also have Lucy the ferocious Pit Bull. :-)
Cynthia & Gary
Jeffrey 25
Angel 14
Aaron 6
99 Explorer EB
98 Expedition EB
93 Palomino Filly
04 Fleetwood Hemlock
http://community.webshots.com/user/cynthiacook777
34 Nights camping in 2008
37 Nights camping in 2007
26 Nights camping in 2006
Al/Reeni
Ft Myers, Fl
jay427 wrote: you could buy a ball, cut the bolt off then use your trailer lock to lock the ball down, just a thought.
We had one of are trailers at work with one of those fancy ball/cover locks and sombody just drilled out the keyway and took it off.
That's what I use on all my trailers. Cheap and effective.
Mike Up
NW Indiana section of Chicagoland
I've been using that same lock on my current Starcraft and on my previous Rockwood. Neither would clamp down with the lock in, but that's not the purpose. It's suppose to clamp around the lip, with it's extending, key locking, shaft.
Have a good one.
2008 Eureka Copper Canyon 1312
13'x12' Tent
(Hoping to purchase!) 2008 Jayco Jay Flight 19BH
2008 Ford Explorer Sport Trac 4.6L V8 4X4
292 Hp, 300 lbs torque, 7000 lbs towing, 730 lbs hitch
Tow-N-See Convex Mirrors
catvet
Atlanta
aaronthegiant wrote: ...
Trailer in the driveway with the hitch towards the garage, not the street...
I give up...how do you move a 3500# camper if the hitch is up against the garage?
Catvet
aaronthegiant
Maryland
Quote: I give up...how do you move a 3500# camper if the hitch is up against the garage?
Catvet
That's the whole idea! Actually, I just mean facing the garage instead of the more theft inviting position of facing the street. Though, I almost have to pull into the garage (around the trailer) in order to back up correctly to hitch up. Again, not much of a hassle for me, but to a would-be thief it's less attractive....hard for a quick get away.
2007 Fleetwood Niagara
2005 Ford Explorer XLT 4WD
Reese WDH | Sway | Brake Controller
in_da_keys
Memphis Tn
I use this method.
LINKY
Sleep very well at night!
Nights Camped 2006 = 20
Nights Camped 2007 = 23
Nights Camped 2008 = 17
2004 Jeep Wrangler Unlimited
2005 Jayco 806U
My Pictures
midsouthjeeps.com
lc-12
MO
New2RVees,
I am using the exact same lock that you have with no problems! It does fit a bit loose, and the coupler does NOT clamp down, but the hitch is covered therefore doing it's job!
I also worried about this at first, but worrying was not the answer.
Just push the "lock" in as far as it will go, lock the unit with the key and take off for another adventure!
New2RVees
Chatsworth, CA
Thanks, all.
Yeah, the coupler lock is mostly for show anyway.
Again, the only thing that made me think something was "wrong" with the lock was the picture on the packaging, which shows a coupler clamped down on the lock ball, and the sliding "bolt" of the lock clamping down over the closed coupler.
In fact, it doesn't work exactly that way for me, but it's still as effective as a coupler lock can be.
Actually, the BOC is the best visual deterant! I bought the thickest/strongest chain I could fit through my mag wheels/brake assembly, and a heavy-duty hardened-steel "contractors" lock. The only bummer is now I'm carrying around an extra 20 pounds (or so) in chain/lock weight! Makes my PUP look like some sorta wild animal!
