milkman41
CA
I am putting this post up because I'm sure someone has done some research (and/or) used these two hitches. I would like to get anew air type hitch-am considering the Air Ride and Air Safe. Any comments would be appreciated.
33Ft Royal Villa
07 Chevy Silverado 3500 HD Diesel
FiverBob
Sarasota, Florida USA
I think you will find they are one and the same. They went thru a slight name change last year or maybe the year before. I have the Air Safe and am very impressed with it.
Bob
2003 Dodge 3500 HO dually 6 speed Laramie, Jordan Controller, RDS aux tank/tool box, Bremen boards, RamAirIII, Jacobs EBrake, Air Safe 25K hitch
Carriage 36' Triple slide Fiver, Onan Gen, Sat, Prosine Inv., MORryd IS and pinbox
Airstreamer67
Pineville, LA USA
I bought my AirSafe hitch for use on my travel trailer in 2005 and have used it from coast-to-coast. To save time, let me just say that everything they say on their web site has proved to be true for me. It's a great device.
marspec
West Virginia
I'm glad I brought mine.
Cat320
Western AR
milkman41 wrote: I am putting this post up because I'm sure someone has done some research (and/or) used these two hitches. I would like to get anew air type hitch-am considering the Air Ride and Air Safe. Any comments would be appreciated.
33Ft Royal Villa
I went through the same thing a few years ago. I finally decided to get an air pin box rather than an air hitch. The ride is not quite as good, but the cost was one third as much.
Navychop
Fairfax, VA, US
Perhaps your consideration may be between the Air Safe and the TrailerSaver.
The TrailerSaver comes in one piece with only 2 bags. It should be deflated before hitching/unhitching. One person will not be able to lift it, you'll need a hoist or crane or some such. The 4 bag Air Safe (I have the 25K) can be disassembled into 4 parts that one person can handle. Important to me, as I need the bed far more often than I tow.
An air pin box goes with the trailer (probably wouldn't fit your next rig anyway). An air hitch will work with future rigs. And you might as well get the 25K.
edited to correct product name. Brain burp.
edited 04/11/08 04:32pm by Navychop *
2004.5 Dodge 3500 Laramie Quad LB SRW CTD 48RE 4.10 4x4
97 30' Coachmen Royal TT traded in April '08 on a
2008 Keystone Challenger 35CKQ fifth wheel
Air Safe 25K air hitch
Kipor 3500Ti (avoid- no support)
CardinalCamper
Wichita Kansas
Just bought a Air Safe 25k. I emailed lots of Air Safe owners and did not get one negative reply.
The Trailer Saver seems like a good quality hitch what turned me away was having to buy spacers if it was not the correct height you needed.
And I also like the 4 Firestone Airbags that comes with the Air Safe.I have a set of Firestone Ride-Rite Airbags on my truck and they have been great. Been 3 yrs. and no leaks good quality.
Trailer Saver I think have goodyear air bags.But it's your decision to make go with the one that best fits your needs and setup.Good luck which ever one you decide to go with.
Charles & Dawn
2005 Cardinal 35 CKT LX
2000 F-250 PSD 7.3 4x4 CC,5" Dual Exhaust, Hypertech Power Programmer III, Firestone Ride-Rite Airbags, Air Safe 25K Air Ride Hitch,RoadRunner 50cc scooter
Basset Hound (Shorty)
22geno
Noble Ok
They look the same and the name change could of came about when Lippert bought them.
Gene"n"Betty 2003 G.M.C. 3500 S.L.T.ext cab dually duramax/allison
2006 32ft Open Road 3 slides. Just the Wife, me and Dusty a loud mouth Parrot.
larry barnhart
wenatchee. wa usa
If this is true I guess Lippert is taking over the rv welding jobs. good or bad????????????? chevman
