RV.Net Open Roads Forum: Beginning RVing: Water tank question??????
 > Water tank question??????
yesitsfree
Central Ohio
Posted: 04/11/08 12:11pm Link  |  Quote  |  Print  |  Notify Moderator
Ok I am reading about dewinterizing the rv and see how to clean the tanks with bleach solution. What would we do with our holding tanks? We have never hauled water in them always used city water hookups, shouls we still fill the holding tank with bleach/water solution and then pump that solution through the lines and then do it again a few more times with just plain water and pump it through the lines as well?
ScottG
Bothell Wa.
Posted: 04/11/08 12:14pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, thats what I would do. Also, after I de-winterize I drain a glass full of water directly out of the fresh water tank and look for any floaters.
Scott, Grace and Wesly
2003 Dodge 3500 4x4 Cummins (lightly bombed),
dbbls
Missouri
Posted: 04/11/08 12:24pm Link  |  Quote  |  Print  |  Notify Moderator
You should pump the treated water through the lines and let it set for several hours. It takes time for the chlorine to kill all the critters. don't over so the bleach or you will be forever flushing it out. If I remember correctly it is about 1/4 cup for 40 gallons of water.
1999 F250 Superduty, V10 with Banks Power Pack
2004 Colorado 29RL 5th wheel with 3600 watt Onan
Martyn
Bennett, Colorado, USA
Posted: 04/11/08 12:55pm Link  |  Quote  |  Print  |  Notify Moderator
Always flush and sanitize your freshwater tank. You never know when you'll need it!
2004.5 Dodge Ram 2500 QC CTD 4x4 SLT; 2007 Coachmen Chaparral 267RLS;
Reese 15K Slider;Prodigy;JT Stabilizers;2 Honda EU2000i's;
2006 Glastron MX175;
rv-forums
2005 Dodge Magnum for the DW
skipnchar
Topeka Kansas USA
Posted: 04/11/08 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
Good advice about sanitizing the fresh water tank but holding tanks do not need to be sanitized. Waste water doesn't CARE if they're sanitized or not Good luck / skip
jay2003
San Joaquin Valley, California
Posted: 04/11/08 02:15pm Link  |  Quote  |  Print  |  Notify Moderator
I've been using the bleach method for a while now with no problems. I don't drink the water from the tank though but the kids take baths and since they're little the water ultimately ends up in the mouth at some time.
I started using this stuff though Thetford Fresh Water Tank Sanitizer and after reading how it's done I actually feel a little safer should I actually have to drink the water at some point. I don't feel that after sitting all winter that bleach alone is sufficient enough to kill everything. Probably is if you're a full timer or use your trailer more often. Sorta like a swimming pool that sits all winter long. Sometimes you have to throw in an extra dose of chemicals to really clean the water up for summer (they call it shocking a pool) then once that's done then you can use the chlorine (bleach) to maintain the tanks.
Just my .02 cents.
05 Toyota Tacoma DC 4x4 SB Off-Road Package w/Tow 128" WB
2005 KZ Jag 24JB*Newer Model Floorplans Slightly Different
Prodigy Brake, WD hitch, friction sway
Garmin GPSMAP 60CSx
Honda EU2000i Generator
Me.. the wife, the 5 year old, and the 2 year old
Hornet28BHDS
Parker, PA
Posted: 04/11/08 02:36pm Link  |  Quote  |  Print  |  Notify Moderator
You've got it!
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
Kirk
Livingston, Texas.
Posted: 04/11/08 05:22pm Link  |  Quote  |  Print  |  Notify Moderator
Your fresh water tank should be sanitized along with the complete water system at least once each year. It is both for health reasons and to prevent any growth of algae. We have been full-time now for 8 years and we drink the water from our system every day. With proper care it is no different than using tap water at home.
You can find detailed instructions on how to sanitize by going here.
Good travelin! ........Kirk
sent via Starband, Manual Flyer dish
www.adventure.1tree.net
