RV.Net Open Roads Forum: Class A Motorhomes: Screen Door Rattle while Driving
 > Screen Door Rattle while Driving
deerhntr
Kutztown,PA
Posted: 04/11/08 12:31pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2008 Newmar Baystar with approx 1000 miles on the unit. The unit is equipped with the standard screen door found on most motorhomes and travel trailers. As you all know, this screen door captures in the solid door when opened and closed. The latch that captures the screen door does not have any adjustment to tighten that capture or prevent the door from rattling in the door frame/jam while driving.
I was wondering has anyone has come up with any unique ways of "quieting" the rattle these screen doors produce while driving. One thought I had was to install some foam weather strip around the screen door jam to absorb the rattle. Any other thoughts? Thanks in advance.
Russ F.
Kutztown,PA
driveby
Vancouver BC Canada
Posted: 04/11/08 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
it is a rattle or squeak? foam works for rattles but I'm battling a squeak. Darn I5!
2008 Itasca Sunova 35J Class A
1997 TJ Sahara, hard and soft tops and AC
Held together via Roadmaster Falcon 2 tow bar and stopped by US Gear Unified Brake system.
tmmar
Nassau County, Long Island, NY
Posted: 04/11/08 12:58pm Link  |  Quote  |  Print  |  Notify Moderator
I purchased some self stick foam weather stripping with peel of backing and ran it around between the 2 doors to take up the slack. Worked for my rattling problem.
2008 40' Forest River Berkshire DP Bunkhouse
03Ultra
Central Massachusetts
Posted: 04/11/08 01:23pm Link  |  Quote  |  Print  |  Notify Moderator
Rubber feet at the corners also works.
2004 Itasca 36M Workhorse
03Ultra
Posted: 04/11/08 01:24pm Link  |  Quote  |  Print  |  Notify Moderator
Check and see if you can put foam inside the jamb around the door. It sounds like the door may be rubbing in the jamb while underway.
wshrman
Orange, Ca.
Posted: 04/11/08 02:13pm Link  |  Quote  |  Print  |  Notify Moderator
I used the little plastic stick-on buttons, got them at the office supply store.
They have them in different sizes and thickness. Put them on the door in several spots, when the screen door latches to the door fits nice and tight, no rattles or squeaks.
2000 Rexhall Roseair 3450 V10, GearVendor, AutoFormer
2001 Ranger, Remco, BRAKEbuddy
Belgian Sheepdogs, Blazer & Chayna
Shareholder Pismo Coast Village
hwybnb
Posted: 04/11/08 02:14pm Link  |  Quote  |  Print  |  Notify Moderator
I use a rubber wedgie door stop between the screen door and the solid one. I put a tether on it so si doesn't get lost.
deerhntr
Kutztown,PA
Posted: 04/11/08 02:34pm Link  |  Quote  |  Print  |  Notify Moderator
I hadn't thought about the plastic/rubber stick on buttons. I like that idea. The "hard door" does have 2 rubber feet on the door to dampen the screen door, but the "rattle"(Not squeak) comes from the door jamb. I thinks the rubber buttons will work their.
Thanks,
Russ
1fastdad
mo.
Posted: 04/11/08 03:02pm Link  |  Quote  |  Print  |  Notify Moderator
If you could find a later model dolphin and look at theirs. Like mine they have rubber knobs that hold the door tight when it is against the main door.
Gadget Guy
Whitefish/Calgary
Posted: 04/12/08 09:14am Link  |  Quote  |  Print  |  Notify Moderator
I used self stick weather stripping foam on my screen door. I just cut 8 small 1/2 inch long pieces and stuck them to the door at equal places. Stopped all squeaks and rattles.
