RV.Net Open Roads Forum: Toy Haulers: WW Water Heater
Search only in Toy Haulers
 > WW Water Heater
mpeltzer
Posted: 04/11/08 01:11pm Link  |  Quote  |  Print  |  Notify Moderator
We just bought a used WW FS2600. When we were out in the desert last weekend, when the wind kicked up, our water heater wouldn't work. Does anyone have any information on how to fix this problem (other than not go out in the wind)?
UPDATE: We fixed the issue by replacing the 'brain'. It cost about $140. But works perfectly now.
* This post was edited 10/07/08 12:34pm by mpeltzer *
'04 WW FS2600
'04 Ford Excursion
'04 KTM 450
'03 Honda XR70
'05 Honda CRF50
'05 Yamaha Raptor 80
skipnchar
Topeka Kansas USA
Posted: 04/11/08 01:33pm Link  |  Quote  |  Print  |  Notify Moderator
That is one of the BIG advantages of getting a DSI water heater (with electronic ignition). Wind can blow out a pilot light but it won't blow out the main burner so the electronic ignition will continue to work. Most heaters with pilot light ignition will have a wind guard that is SUPPOSED to protect against a blow out but it's not perfect. Good luck / Skip
StubbornOne
Escondido, CA
Posted: 04/11/08 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
Did you have to keep re-lighting it, or did it just stop working? I don't know about a 2004, but my 2007 WW has a fusible link that blew and my water heater would not heat. I always carry a spare now.
2007 Kawasaki KFX 90
2007 Honda TRX 90
2005 400 EX
2006 KTM 450XC
2007 WW LE3105
LowRyter
OKC
Posted: 04/11/08 11:39pm Link  |  Quote  |  Print  |  Notify Moderator
Hit the reset button. Clean the terminals. I made the mistake of driving with the WH turned on. A buddy got it work with the reset. Actaully there are two resets. The one on the right kicked it on
Hope that helps.
mtnrider
Poway CA
Posted: 04/12/08 10:38am Link  |  Quote  |  Print  |  Notify Moderator
There is a $.50 in line fuse. Look at the wire connections and you will see it. You cannot tell its blown by looking at it but very common in the wind for those to go out. Just remove it and plug the wire in directly and it should work fine. Not to insult you or anything, but if you are too low on water they won't turn on either. I wont tell you how I figured that one out after an hour...
5 Bikes, all hard pack!
KTM 525/543 CA Lic mine
KTM 250/351 CA Lic wife
KTM 105 SX son. KTM 65 SX son, Honda 230 daughter
07 LE 3505 pulled by Stock DMAX 2500
SMarquez
Rancho Cucamonga, Ca
Posted: 04/12/08 08:50pm Link  |  Quote  |  Print  |  Notify Moderator
I bought a $10 guard that goes over the vent at an RV supply store. It's supposed to block some of the wind. I haven't had a chance to try it yet and I probably could have made one. I saw small pieces of galvanized meal at Home Depot that would probably have worked.
JSGrewal
Simi Valley, CA
Posted: 04/12/08 09:33pm Link  |  Quote  |  Print  |  Notify Moderator
Dont ask how I know this one, but there is a bypass valve for the water heater in my WW. It happens to be in the same compartment I use to store chairs. After a few hours of trying everything to figure out why the water heater didnt work, including cleaning the pilot light, checking the thermal fuse ( I carry spares), and various other things, I resorted to a cold shower. Noticed the valve when putting away chairs...
The heater worked the whole time- wouldnt fire up because it was already hot...
2004 F350 4x4 Crew Cab PSD
2007 Weekend Warrior LE3505+6
dedmiston
Valencia
Posted: 04/12/08 11:40pm Link  |  Quote  |  Print  |  Notify Moderator
Can't tell you how glad I am to see everyone calling it a "water heater". The only thing that bugs me more than seeing toll-free numbers referred to as "1-800 numbers" (didn't we all learn to dial a one before the area code when we were in about third grade?) is to see/hear people call a water heater a "hot" water heater. If the water is hot, it doesn't need to be heated.
/rant
2004.5 Dodge 2500 Diesel • 2005 Weekend Warrior FS2600 • Hooligan #3
Toys:
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
  • 06 Yamaha TT-R90E
The Edmistons - Our Gallery
Never forget 9-11-01 Check out our blogs @ blog.rv.net
mtnrider
Poway CA
Posted: 04/13/08 10:28pm Link  |  Quote  |  Print  |  Notify Moderator
Dave,
You really need to get out and go on another ride!
dedmiston
Valencia
Posted: 04/14/08 07:55am Link  |  Quote  |  Print  |  Notify Moderator
mtnrider wrote:
Dave,
Tell me about it. We've been stuck at home with a house full of puppies since our trampy dog got knocked up over New Years. We're still a couple weeks away from being able to adopt the dogs out, but by then it'll probably be too hot to ride.
 > WW Water Heater
