Bigdog
silverdale wa.
We've got these things all thru the trailer and they all want to fall down all the time.. I know that you gotta slide the dark ones up first and then the white ones,but they still slide down by themselves.. How in the heck do you adjust them if ,at all,they are adjustable...With my luck,that's the way they were designed,just to give us more problems than we already have..
GO COUGARS
2001 Ford 7.3L PSD Excursion
Ride Rite air bags
AFE Stage1 air-inlet
4"MBRP exhaust
Hellwig rear sway bar
2005 Keystone COUGAR 304BHS
Tekonsha Prodigy
1200 Equalizer hitch
2008 Thomas w/Mercedes-Benz 78 pass. school bus
Deen
Vancouver, WA
Turn the spindle at the bottom a little to tighten up the cords. You'll have to loosen the screw in the center of the spool and be sure to take the same amount up on each side or the bllind will not be level. Then tighten the center screw again. Might take a little experimentation to get it right.
Deen - Vancouver, WA
'02 Dutch Star 4090 (41+', triple slide)
435/1200 ISC Cummins/Banks PowerPak
'08 Honda Civic/dolly
'05 Honda Odyssey/dolly
NRA Benefactor Life Member
FMCA f47302s, Life Member: Good Sam,
Newmar DP Owners Group
51st yr of RV'ing
forty4san
Hollywood, FL
I used Google and typed in "adjust day night shades" and this was just one of many inforamtional sites. Adjusting Shades
Susan I
2008 McKenzie Starwood 32 FKD TT
03 3500 Quad HO Diesel DRW 4:10
Fulltiming, On the road somewhere.
MrTravelDecal
wandering
I believe you loosen the screw that holds the little spool to the wall that the cord wraps around. After you loosen the screw wind up each spool with a bit more tension on the cordage. Do each side evenly so that the pleats of the blinds will hang level. after you add more tension to the cords tighten up the screw that holds the spool to the wall a little in order for the tension to stay held. Then your blinds should stay wherever you adjust them to. Mine hold no matter where they are st at on the bumpiest of roads too.
Like old travel decals? me too!
The reason talk is cheap: because supply exceeds demand
skipnchar
Topeka Kansas USA
Some have had great success in adjusting them the "traditional way" by tightening the tension on the lines. I've found that the BEST way to adjust them is to REMOVE all attachments and stack them on a shelf in the garage. That's how I adjusted MY poor quality shades and replaced them with mini blinds and drapes.
Johng
Gilbert, AZ, USA
You will need to loosen the spool with a screw driver and then turn it to tighten the string with a pair of pliers. That's how I adjust mine anyway, sometimes not alot of room but if you work at it you can them tight.
Happy RVing
John and Judy
US Air Force - Retired
05 Beaver Santiam 40DST
08 Malibu Toad/Brake Buddy
WilleyB
Nova Scotia, Canada
Quote: I've found that the BEST way to adjust them is to REMOVE all attachments and stack them on a shelf in the garage. That's how I adjusted MY poor quality shades and replaced them with mini blinds and drapes.
Those who like em! like them a lot, Those that don't like them don't like them at all
Cheers
Vanguard VXL2000
2000 Ford V10 Triton, E350 Super Duty
Just for me,the Mrs and the mutt
Burro
U.S.A.
skipnchar wrote: Some have had great success in adjusting them the "traditional way" by tightening the tension on the lines. I've found that the BEST way to adjust them is to REMOVE all attachments and stack them on a shelf in the garage. That's how I adjusted MY poor quality shades and replaced them with mini blinds and drapes.
Right ON! Now to convince my DH...
Bigdog
silverdale wa.
I'm not sure about changing them 'cuz we upgraded the window mini-blinds to a better quality on our last trailer and weren't too happy with those either.. My only wish about the Day-Nite shades would be that they would be TRUE Day-Nite.. In other words,they need to make the nite part REALLY, REALLY dark to really keep out the sun during the day. The day part is ok as it does shield the inside from a lot of bright daylight and makes for privacy..I took a large piece of that insulated aluminimum material and made covers for the inside of the bedroom windows to keep the lite out and it actually does insulate the windows..(we use our trailer all year round) I used duct tape to fasten them up,but will be re-doing them with velcro before we leave this summer.. I also used it on the pix window in the dinette where there are two smaller windows on the bottom that open keeps a bit of privacy and also insulation.
HeresLucy
Southeast FL
You make me laugh. We went a step further -- all of ours went in the trash. It was one of the happiest days of my RV life. They were not working anyway. We now have the new MCD Duo Shades everywhere except the front windshield. We love them.
Lucy
2006 Allegro Bus 40' DP
2005 Grand Cherokee
Visit Here's Lucy for CG reviews, trip experiences, etc.
