laredo32rs
I have an 07 laredo 32rs fifth wheel. We are having a problem running the a/c and water heater at the same time. We have had a certified electrician look at the camper because when those 2 things are on we can't use the microwave or toaster or a variety of other things, without the breakers popping. the electrician said with the a/c and water heater it is pulling 27 amps (it's a 30 amp rig). Is anyone else having this problem?? Shouldn't it have been designed as a 50 amp so that we can use these things at the same time???
HpyKmpr1962
Lockport, NY
Pretty much the norm for the RV industry.
Your total load may be just below the RV capacity, but the start up surge will get you every time.
Upgrading to a 50 amp service is costly, and most complain about the cost of the rigs as it is now.
Besides you are still limited by the park's capacity to supply you with 50 amps.
Most of us just turn off the AC when you want to use the micro wave or a hair dryer.
Happy trails.....where ever they lead to...
1992 30 ft. Dutchman Classic 2 br (rear bunks) 7500 lbs. "wet"
2003 F-250 2wd Super Duty / Super Cab 6.0 diesel (All Black)
Dale & Mary Ellen
pritch272
Martinez, GA
We have a 30 amp system, we don't try to run everything at once, we don't even bother with the electric water heater, it uses very little propane and is quick to heat up, so we leave it on gas.
You'll need to monitor and manage your electrical loads to keep within 30 amps, there is no other option, unless you want to do an upgrade to 50....
Retired US Army
2000 Ford F250 SD 7.3 PSD, Firestone Ride-Rite⢠air springs
2007 Keystone Laredo 29RL, Doran Pressure Pro and Metal Tire Valves, 16" Michelin XPS Ribs, Dirt Devil CV950 Central Vacuum, 2000W AllPower (Honda Clone), 4000/3500W Champion C46540
Intheloonybin
Twin Cities, Minnesota
We have run an extra extention cord off of the post (they usually have extra 120 volt 15 or 20 amp breakers) to the unit to run extra things if need be.
HVAC instructor
2001 Chevy silverado 5.3 V8 1999 Coleman Niagara
2 Great girls 13 and 11
1 Great wife
Looking forward to fall/winter camping!
Luke Porter
Not on the road :(
laredo32rs wrote: Shouldn't it have been designed as a 50 amp so that we can use these things at the same time???
50 amp power is a feature that costs more for the manufacturer to install. Sometimes it's an option. Sometimes it's included in the base unit.
It's something one should be aware of before buying an RV.
States I have spent the night in my current rig, bought three years ago.
Have RV'ed through 49 states and been in all 50, just short of my half-century.
sprinterowner
tyngsboro,ma
I have the same problem in my Keystone Sprinter.
Keystone Sprinter 311 BHS
2007 Silverado 2500HD "classic" CC Duramax/Allison Greystone metallic
Wayne Dohnal
Banks, OR.
12 amps - water heater
13 amps = air conditioner
13 amps = 1000 watt microwave
5 amps = power power converter (estimate for 'typical')
3 amps = refrigerator element
46 amps total, can't run them all at once with 30 amp service unless the rig has a power management system, which 5th wheels typically don't.
2009 Fleetwood Icon 24A
LinkPro battery monitor
EU2000i generator
mwebber78
New England
Fridge and water heater are very efficient on propane. I run both on propane and I tend to have less issues with running multiple items.
Michael
2 DD's and my DW
6 Acre's of Maine
2009 Crossroads Cruiser CF31SB
2008 Chevy 2500HD Ext. Cab LT 4X4
Camping Pictures
fla-gypsy
North Florida
Very normnal for all 30 amp RV's. You just have to think some before you turn on all electrical appliances. No need to run water heater all the time either. Turn on both heating sources when needed and it will be hot in minutes.
05 Super Duty XLT CC 5.4/3.73 5 sp auto Torqshift
06 Keystone Hornet 29 RLS/(The"Cracker Cabana")
Reese HP Dual Cam
Camping Photos
Northeast Florida Camping Club
St Andrews SP cult member
hankpage
Point Pleasant, NJ
It's not only Keystone. 30 amps just goes so far. We only use the electric water heater if we are not using AC. If you are tripping breakers in your panel check the voltage coming in .. you may have a bad plug or connection or not getting full voltage from CG. If you are tripping the CG circuit your just using too much.
Hank & Lynn
07 Cougar 290RKS 5th wheel
04.5 Dodge 2500 HO CTD,QC,2wd,LWB,Prodigy, Ride-Rite
REAL TRUCKS RATTLE
Our getaway vehicle
'07 Cougar mods.
