Griswolds-5
Santa Cruz
Hi - I have a 2001 F-150 Lariat 4wd with 5.4 Triton and tow package.
There are two gearing options not sure what I have...if you have a F150 interested in what your pulling, please provide the following:
a) Year of F150
b) Motor
c) Gearing
d) 4WD or 2WD
1) Trailer?
2) Length
3) Dry wt
4) Gross wt
5) How does it tow?
Thanks
b_salgado
Salisbury ,NC,USA
Griswolds-5 wrote: Hi - I have a 2001 F-150 Lariat 4wd with 5.4 Triton and tow package.
a) Year of F150
b) Motor
c) Gearing
d) 4WD or 2WD
1) Trailer?
2) Length
3) Dry wt
4) Gross wt
5) How does it tow?
Thanks 2004 F-150 Crew Cab
5.4
3.73
4x4
Edge tuner
Flowmaster Exhaust
Cooper Discoverer ATR load E tires
Stock suspension, no add a leaf, no air bags
Dead level when hooked up!
Trailer: Trail Bay 31 BH
33'-11"
6328
9785... 8500 ready to camp with 1/3 tank of fresh water
1080 tongue weight
Trailer tows great. Flat ground, 63 MPH, OD off, 11 MPG. Steep grades 6%+....2nd gear, 30-40 MPH working it's butt off.
Rolling hills.... 3rd gear, torque converter unlocked occasionally, speed maintained, comfortable.
Equal-i-zer 12,000/1200 hitch and Prodigy controller
04 Lariat Supercrew 4x4,5.4,3.73, Edge tuner, flowmaster duals
06 Trail Bay 31BH, nicely optioned
Equal-i-zer
Prodigy
Follow vehicle, 05 KIA Sorento EX for the golden retrievers.
skipnchar
Topeka Kansas USA
a) Year of F150 2004
b) Motor 5.4 24 valve engine
c) Gearing 4.10
d) 4WD or 2WD 4X2
1) Trailer? 8314ss Rockwood
2) Length 34 feet
3) Dry wt I've never pulled it empty. Loaded weight is 7900 lb. with 1,200 lb. tongue weight.
4) Gross wt 9,200 lb. including cargo in truck
5) How does it tow? 75,000 towing miles without ever needing a repair (105,000 TOTAL miles, still no repairs except brake pads at 85,000 miles)
Thanks
esizemo
Indiana
2002 F150 Supercrew
5.4
3.55
2WD
2008 Jay Feather 30U Jayco
33 feet
Dry 6149 950 lb tongue
Gross ? 7000
HP dual cam 1200/12,000 set up. Tows Great.
jdew1920
SE Michigan, USA
See signature for vehicle info
1) Trailer? Sunline T276SR
2) Length 28'
3) Dry wt 6200lbs
4) Gross wt 7000lbs loaded
5) How does it tow? Good, Very stable with reese dual cam.
'06 F150 SuperCrew 4x4 5.4L 3.73LS 150"WB
'06 Sunline T276SR
maskins
Goldston, NC
b) Motor 5.4
c) Gearing 3.73
d) 4WD or 2WD 4wd
1) Trailer? 2008 Sunset Trail ST28BH
2) Length 32
3) Dry wt 6500
4) Gross wt 7775
5) How does it tow? great
2005 Chevy 2500HD
Colt: The original point and click interface.
jeanspach
New Mexico
See signature for TV and TT info. It tows well in the flats. We go into the mountains a lot where it will drop down to 2nd gear and on really steep grades, 1st gear.
Joel & Leesa
2001 F-150 SuperCrew Lariat Offroad 4x4 5.4L 4.10 LSD Tow Package
2005 Trail-Lite 8308S 5,162# dry
2 Honda EU2000i, 4 GC2 batteries
jeanspach
New Mexico
jeanspach wrote: See signature for TV and TT info. It tows well in the flats. We go into the mountains a lot where it will drop down to 2nd gear and on really steep grades, 1st gear.
I forgot. TT is 30 ft long with 1 slide out - comfortable for us. I haven't weighed wet or the combination together. I estimate loaded adds about 1,200 lbs.
Welfarewagon
Lexington, KY.
2007 Rockwood 8317SS
33 ft.
6100 lbs empty
2006 F-150 Screw
3.73 rear
4X4 towing package
Magnaflow exhaust
Edge Evolution tuner
K & K filter kit
2006 Ford F-150 Supercrew
Prodigy Brake controller
Equalizer WD Hitch
Topsail Cult Member
smkettner
2001 5.4 4.10 4wd, Pulls ~7500 loaded. No troubles across hot deserts or up high mountains.
