RV.Net Open Roads Forum: Truck Campers: Super spring question
 > Super spring question
musqwa
Airdrie , Alberta Canada
Posted: 04/12/08 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
Every time I go over a large bump, or hit one of those unavoidable pot holes that seem to bloom in spring,it sounds like the back of my truck is going to fall off. This has only started since I had the Supersprings and Torklifts installed and with no load, I have shook everything I can find under the truck but can't find anything loose.
Is it possible that the tension is briefly unloaded on the Supersprings and that is causing the noise,has anyone who uses Supersprings experienced anything like this?
Sportsman Matt
Blackstone, MA
Posted: 04/12/08 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
I haven't had that symptom, but I do hear the springs creak and the rollers move when driving unloaded and hit bumps and potholes. I would suggest checking each of the polyurathane rollers for flat spots, If you have flat spots on the rollers, replace the rollers. Also check where the rollers hit the springs, you may have them hitting at the end of one spring, rolling off and creating the slapping or banging noise. Also check the torklifts, make sure they are bolted in solid, sometimes the bolts on the upward mount loosen and rattle under the bed.
Good Luck
Matt
Life is short, Play harder.
2002 GMC Sierra 1500 Regular Cab Long Bed 4.3L V6 Automatic 2WD
1989 Sunline C-750 Slide In Truck Camper
7'6" Floor, 11'6" OAL
Fishing and Hunting New England and eventually the world
2324delk
Middle Indiana
Posted: 04/12/08 07:08pm Link  |  Quote  |  Print  |  Notify Moderator
It happened to me also, It was the rear shackle on the superspring hitting the back side of one of the old springs. It happened on small bumps that were loading the superspring a little. When the camper was on, the superspring flattened out and the shackle cleared. Loosened the superspring clamp, and tapped spring to the back of the truck.
I drive a chevy, so I have the attachment kit under the spring.
Steve
Fish 'n ' Grits
Hollywood, SC , USA
Posted: 04/12/08 07:12pm Link  |  Quote  |  Print  |  Notify Moderator
The only noise I get from my Supersprings comes the first mile or so after I load the camper. I guess the creaks and groans are all the parts settling in to a new position. After that, no sound at all.
Billy & Dale
'99 F350 DRW Superduty
'02 Starcraft 853
Salli the "Schnoodle"
Ladybug the Jack Russell Terror (not misspelled)
Grodyman
Posted: 04/12/08 08:51pm Link  |  Quote  |  Print  |  Notify Moderator
There have been a few people note that Supersprings make noise after installation. I just bought a set of Hellwig Pro Series Silent Ride helper springs, and hope to install this weekend. It will be interesting to see if the urethane sleeves in fact prevent this phenomenon.
I went Hellwig over Supersprings with the intention of removing the outer u-bolts when not carrying the camper, thus not harshening the unloaded ride. When it's time to load the camper, I'll just re-install the outer u-bolts, probably a 15-20 minute job at most.
2006 Dodge 2500/CTD/Quad/2WD LWB, Vision/245/19.5, Ride-Rite, Hellwig Overloads, Torklift/Superhitch, Fastguns, Line X. 2007 AF990 WetBath.
narcodog
Georgia
Posted: 04/12/08 10:41pm Link  |  Quote  |  Print  |  Notify Moderator
Have you lowered the pressure in your tires?
Crumm
Fairbanks Alaska
Posted: 04/12/08 11:32pm Link  |  Quote  |  Print  |  Notify Moderator
wrong idea.. Delete please
96' F350 PSD with smoke added, Airbags, Trailmaster SSV shocks, 315/75R16 Toyo M/T, Centering guides.
06' Adventurer 90FWS with leg extensions
06' Jetcraft XS.
94' Wells Cargo 7'x14'
Slide-Show
Gary3
Windsor, ON
Posted: 04/13/08 03:24pm Link  |  Quote  |  Print  |  Notify Moderator
I don,t notice any noise from the superspring but the overloads have worn a indentation into each superspring,maybe it would be a good idea to file the sharp edge off the over loads.
Gary  Lance  1181 solar Gen.
Chevinator
Keizer, OR
Posted: 04/13/08 11:53pm Link  |  Quote  |  Print  |  Notify Moderator
I had the same problem and here's what I did: I jumped up and down on the bumper of my truck (unloaded, parked) and had a friend watch the springs to see which one was making all of the racket.
I found out it was the passenger side superspring at the front of the spring where it wraps around. They just didn't make the arc on the end tight enough to keep the springs from slapping eachother.
I fixed it by stuffing a piece of heavy rubber between the springs and later I took it out and just set the springs on the tighter setting (top holes), the lower setting was barely contacting the rollers.
Might want to try this no-buck solution.
C
2006 Chev 2500HD Ext Cab 6-0hh gas 2007 Apache Chief 10.55SS Polar Cub EU2000i Supersprings Superhitch Torklifts
