RV.Net Open Roads Forum: Class C Motorhomes: SENECA MIRROR
Open Roads Forum  >  Class C Motorhomes  >  Super C
 > SENECA MIRROR
Pigkisser
West Texas
Posted: 04/12/08 04:49pm Link  |  Quote  |  Print  |  Notify Moderator
I need to adjust the right outside rearview mirror on my 2007 Seneca. The mirror barely "peeks" around the side of the coach, offering a very limited view. I have used the electric adjustment, but I still don't have a good view because the mirror head is simply not far enough to the outside of the coach.
I notice there are some detents which allow the mirror arm to be repositioned. However, the detent either locks the arm too far forward or too far to the rear. Is there a way to readjust the mirror arm detent? Also, I was wondering about readjusting the entire mirror head assembly that attaches to the arm (trying to swivel it outward). Has anyone done this?
2007 Jayco Seneca 33SS
2008 Jeep Wrangler 4 door 4X4 toad
Ready Brute/Ready Brake tow bar/brake combination
Igloo Ice Chest
az99
N.Y.
Posted: 04/12/08 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
I just push mine a little past the detent and it stays there. There is enough resistance to hold it between the detents.
JohnInAz
Arizona
Posted: 04/12/08 09:24pm Link  |  Quote  |  Print  |  Notify Moderator
I have the same issue. The arms for the awning block about half of the visibility in the mirror. My only solution is to make sure that mirror is really clean along with the passenger window. I have the little mirror adjusted so I can see the blind spot (more or less) and otherwise have become used to the amount of visibility.
2007 Jayco Seneca 34SS
2006 Jeep Grand Cherokee toad
zkathyz
Newhall, CA
Posted: 04/12/08 10:42pm Link  |  Quote  |  Print  |  Notify Moderator
We had that same problem. My DH complained so he fabricated a new part to extend the mirror out from the body and now it is 100% better. You can actually see all along the side of the rig and the road behind, exactly like the left mirror.
The Beast and The beloved
Jayco Senecca 34SS & '84 Mobile Traveler
Always in our memories
5etechsupport
South Florida
Posted: 04/13/08 04:24am Link  |  Quote  |  Print  |  Notify Moderator
As AZ99 states, just move the entire assembly out just a little and it will stay there. The mirror assembly which attaches to the arm is fixed, it is not adjustable. Only the arm where it attaches to the vehicle can be moved. I went just a bit further and bought a 4" adjustable fisheye mirror which I attached to the upper right corner of the flat mirror. Makes a tremendous improvement in visibility.
ronfisherman
SE Michigan
Posted: 04/13/08 05:08am Link  |  Quote  |  Print  |  Notify Moderator
Getting a good view down right side of a MH is a common complaint. I added a Tow-N-See Mirror convex model to our Kodiak chassis. Put it in upper right corner.
Saf-TTE tire monitor
paulin
No. CA
Posted: 04/13/08 11:41am Link  |  Quote  |  Print  |  Notify Moderator
Can you provide any more information, perhaps a photo too?
Thanks,
Paul
Paul & Linda
2007 Jayco Seneca HD 34SS Duramax
2005 Saturn VUE
"Monty", "Maggie" & "Murphy" the mighty Shih Tzus
FMCA #F375077
Major Domo
Southern New Jersey
Posted: 04/16/08 05:54pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Gulf Stream Conquest Super C on the Chevy/Kodiak chassis and have great mirrors much bigger than the Seneca 36MS that I have been looking at. Not sure why the mirrors are different on the same chasis. I was thinking that if I purchased the Seneca I would put on the same type mirrors that I presently have.
dleslie125
Southern Ontario/Palmetto FL in Winter
Posted: 04/16/08 08:13pm Link  |  Quote  |  Print  |  Notify Moderator
Are you sure they are different? Your comment that they are surprised me given they both buy the same product from GM. When I look at photos of your unit and the Jayco, the mirrors look identical.
D
Don, Bev & Phil
07 Jayco 32SS on Kodiak May 07 Yahoo Kodiak Group
06 HR Amb 40PLQ ISC 330/950 9/05-5/07
04 Winnie Jrny 39W CAT C7 7/04-9/05)
00 Triple E Commander 5/03-5/04
Toad - 07 Tahoe LTZ 12/06 -
04 Colorado Z71 04- 06
dleslie125
Posted: 04/16/08 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
Ron, I'd be concerned about the possibility of having to buy a new mirror every few days after it fell off. I assume you have found it sticks on tightly with little risk of losing it?
D
 > SENECA MIRROR
