RV.Net Open Roads Forum: General RVing Issues: Surge Guard noisy??
 > Surge Guard noisy??
KC8WX
OH IO
Posted: 04/12/08 05:28pm Link  |  Quote  |  Print  |  Notify Moderator
Had the TT powered up today for appliance testing and got out my brand new Surge Guard Model 34730. When I hooked it up and put AC Power to it, it hums annoyingly like a big transformer. Reminds me of a Mercury Vapor light on a pole or ceiling.
Anyone using one of these have the same results? Sounds like Transformer Hum, but could be something touching the inside of the plastic case and resonating the hum through the plastic box making it louder than it is supposed to be. Just want to make sure it is normal with these and hoping I didn't get a bad one.
2006 Durango SLT 4.7L, 545RFE, 4.10 Motive Gears with TracLoc 2WD AIRAID Cold Air Intake, PML Deep Tranny Pan, KYB Shocks
2007 Wildwood LE 27RB
Equalizer Hitch
Prodigy Brake Controller
snookmjt
On the road
Posted: 04/12/08 06:23pm Link  |  Quote  |  Print  |  Notify Moderator
Have used a Surge Guard for a few years and never heard a thing from it.
Tim and Mary Jane
Mandalay 40B
marvmarcy
Polson, MT, USA
Posted: 04/12/08 07:02pm Link  |  Quote  |  Print  |  Notify Moderator
It depends on how and where you mount it. It hums, and the sound may be amplified by something. I've had them in my last three rigs and never had a problem. The main noise I hear in this rig is a loud clunk when it turns on power, but that is mostly because of where I have it mounted.
JMHO
Marv
2001 Volvo VNL42T420, ISX450/1650, super 10sp w/GearMaster
2003 Newmar Mountain Aire 38RLRK
Piaggio MP3 400 scooter
RVing since 1979 - Fulltime since 2000 (mostly CO, MT, NC & Key West)
Retired USAF
Gdlow
Meridian Idaho
Mine has never made a noise either...except possibly when starting it up..
Gary And Cathy
'05 Dolphin 5342
Honda Element following us
GS, FMCA 365597
Rallys attended
FMCA Albany, Or.'06
FMCA Redmond, Or.'07
axlloy
london ontario canada
Posted: 04/12/08 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
i have one and well when i first plugged it in and it started to flow power - it hummed --- a little hum is normal from what i understand --- it isn't annoying or anything --- i have tapped it gently (with fingers only) and a bit of the hum disapated -- you may wish to give this a try.
otherwise i would contact surge guard and see what they have to say --- oh, it should never be resting on its back (so i have been told).
good luck
tvman44
Southwest Louisiana
Posted: 04/12/08 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
I have never heard a sound out of mine except the clunk when it turns on.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
KC8WX
OH IO
Posted: 04/12/08 07:55pm Link  |  Quote  |  Print  |  Notify Moderator
The one I have is the 30A Portable, so it hangs by the plug from the outlet box on the post. It's definitely coming from the inside, vibrating the plastic case. Did try tapping on the sides, no change, so guessing a wire or the circuit board is against the side of the case causing it. Have to see if I can open it up, or if it's a sealed unit contact SurgeGuard.
Yep it's definitely weather sealed. Got the Star Screws out but it is sealed for weatherproofing. Will just see how it does after a little use on my upcoming campout. If it gets worse will call them, if not I can live with it.
* This post was edited 04/13/08 08:39am by KC8WX *
fredbon
Pacific Northwest or SoCal
Posted: 04/12/08 09:51pm Link  |  Quote  |  Print  |  Notify Moderator
Is this the only power source you have tried with the unit? It is possible the power source was out of specs? Mine will vibrate and sounds like a relay trying to connect if the power is out of limits. My unit has a keyed override, did you try the override?
Just a few things to try.
Fred
Fred and Bonnie
Frankie, Sun Yao Ting, & Seline (Cats)
2005 Dolphin LX 6375
2006 Saturn VUE
As I've Matured... I've learned that artificial intelligence is no match for natural stupidity.
