sistah
Wisconsin
I understand you can put the pot in the sink while traveling. My question is: do you pad the sink with towels or something so it doesn't slip around in there? Any opinions are valued. Thanks in advance.
skipnchar
Topeka Kansas USA
We've used a non-skid rubber mat.
rockylarson
Jersey Shore
I wrapped it with paper towels and padded the rest of the sink to keep it from moving around. You may want to cook on a lower setting because all the extra insulation holds in the heat.
sch911
Rochester Hills, MI
Using them while underway. Unless they've invented 12V crock pot's how do you power them? Generator, inverter?
2003 Damon Challenger 348 Class A - Triton V10
Posted by Macintosh
sistah
Wisconsin
we can use either generator or the inverter.
Nascarcruzin
Home is where the RV is parked.
I place the crock pot in our cooktop, and haven't had a problem, yet, knock on wood.
Ronnie & Rebecca
Check out our journal: North to Alaska
FMCA #388387
Full-time RVer's since 2004
Monaco LaPalma Workhorse chassis 37' 2-slides
jfmoots
Marysville, Ohio
sch911 wrote: Using them while underway. Unless they've invented 12V crock pot's how do you power them? Generator, inverter?
You name it, someone's thought of it!
James, Hollie, 2 boys, 2 dogs
04 Ford F-150 XLT 5.4L w/ 7200# GVWR Package
05 Forest River Rockwood 8318SS
Equalizer Hitch, Prodigy Brake Controller,
Edge Evolution Programmer, Rancho RS9000X Shocks
DarkRubiTJ
Livingston, Tx.
Ours sits on the counter top on a non skid mat never moved in 10,000 miles. We use ours on regular 110v from our inverter, never had a problem. It's great to travel all day and have a nice hot meal when you get there.
keywestrv
key west fl
Be sure to bungee cord the top down.....
She goes really REALLY FAST
2002 Rexair 40' DP Cummins 400HP with Banks
Suzuki GS 290HP Top Gas Dragbike, 0-180mph in 7.5 seconds
Suzuki GS 230HP Bracket Dragbike, 0-150mph in 8.5 seconds
Enclosed race trailer, A/C, gen, compressor, mini-shop
Spin1 pipeline
Pleasant Grove. Alabama
We usually have beef tips,carrots,potatoes,vegetables in (12 Volt)crock pot. We put pot in large boiler (in basement) where if it tips over boiler to catch over flow. Secure (starch cord came with pot)the top on good;and about 8 hr. later cooked then a little rice. Wonderful after a long day of driving. We check it at rest stops every couple of hours to make sure OK. We have cooked this way at least 15/20 time in the past two years.
PS...The 12 Volt crock pot we have works well for two or three people any more need larger pot. (ROADPRO CROCKPOT) 12 volt slow cooker MD#RPSL-350 as posted above by (jfmoots) Roadpro said used 6.5 to 7 Amps.... or 78 to 84 watts.
hope this will help
linda and spencer
