gayles
salt lake city
We bought a Keystone 2005 Cougar 285 with a polar package and can't find info in paperwork or online that tells us exactly what is included in it.The Keystone website only lists an enclosed underbelly. Does it have heated tanks ???? or anything else
Fatbob
el paso tx
I have a Cougar and I think the Polar package is just a sealed underbelly, and a heater duct directed to it. Thats what I was told by the dealer.
Big Bruce
Ocala, Fl. US.
We have the polar package on our cougar and as far as I know the under belly is filled with insulation and enclosed.
Big Bruce
2006 Dodge, Dually, CTD, Quad Cab, 4 X 4, Automatic/ 2006 31' Cougar FW
Hauling (2) 2005 Harley Road Glides.
Or Gone Fishing - 17' Carolina Skiff with Yamaha 75Hp 4 Stoke.
Cat320
Western AR
Check the brochure that's where they like to brag on all the options on the trailers.
Mark Heisler
Viking,Alberta Canada
email customer service for your info
2003 dodge 2wheel drive diesel 375hp 750torque
2007 citation fifth wheel model 29bhs
ak_traveler
Fairbanks, Alaska
*from the brochure on my Cougar*
"Polar Package: fully, enclosed, sectioned underbelly with heated and enclosed dump valves."
"There's no such thing as too much tow vehicle!"
Wes, Linda, & kids
"Tow Twuck" - 2008 Ford F350 DRW CC LB 6.4 Powerstroke
"Cougar" - 2006 Keystone Cougar 289EFS Fifth Wheel
Our Website
jetjane
Saskatchewan
Fatbob wrote: I have a Cougar and I think the Polar package is just a sealed underbelly, and a heater duct directed to it. Thats what I was told by the dealer.
This is what I was told as well. It is a 2" duct according to the construction pictures in the brochure and on their website. We had a 2006 Cougar and found this warmed the floor up nicely. We didn't use it in freezing temps though.
jaminjer
Menifee, California
I have the eastern cougar with the enclosed underbelly. I took the panels off because there were more of a pain. I had rodents use the panels to nest in. All that is under there is the panels and a 2 inch heated duct. I live in and travel mostly in the western states so no need for the underbelly. It has been so much easier to add and modify stuff without the panels.
99 Ford 7.3 SC SD with ATV rack on top
2003 Cougar 245EFS
mods-4 golf cart batteries, 1750 watt inverter with toggle switch installed for living room outlets
clutch1
North Idaho
I too was impressed with the term Polar Package. After buying our trailer I found out what it was. It does sound good though. To me it just means that a lot of propane is being used to heat something that I don't need to heat where I camp.
98.5 Dodge diesel, 4" exhaust, shift kit, Edge EZ, boost fooler, gauges.
03 Mountaineer 5th wheel with two slides
http://www.nwbombers.com
Goin4forty
Wisconsin
Covered and heated underbelly with 2" duct work from the furnace providing the air to warm the tank/valve area. Very little insulation laying on top of plastic underbelly and no insulation on inside of frame rails. Works well down to about 20ºF if not too windy out, below that and I still get some icing in the line that runs to the kitchen faucet. I took off the 2" line and replaced it with a 3" line that I plug unless I know it is going to get much below freezing at night. You don't need to blow warm air down there if is isn't going to freeze. If it is really going to be cold (<15ºF), I place a small fan under the sink and blow air down into the basement through a small, hinged access cover I made. I have camped down to 5ºF with the current set-up and have not had a problem with ice.
2007 34RBH Keystone Challenger
2005 Chev 2500HD CC, D/A, 4X4, Hypertec, Prodigy, Mor-Ryde, Firestone Airbags, JT Strong Arm
2007 Polaris Ranger SE XP700
