MKDSK
Corinth, NY/USA
My television is blurry and the picture has moved down a little bit as I an havinf trouble seeing the words at the bottom of the screen. I want to keep the tv and fix it myself if possible. Anyone out there know what I would have to do to fix these two problems? Thanks
ejforwood
Littleton (Denver) Colorado
There is nothing inside a TV that a Non-Electronics person can fix!
There are things that can KILL you!
The high voltage supply caries several thousand volts long after you have shut the TV off.
Stay out of it!
You have to know how to short the supply to ground before you can safely start messing with things inside!
Sorry but it is usually cheaper today to buy a new TV than to fix an old one.
Jerry, KØEJF
Jerry, Dottie & Chan, "the little furry one"
98 Bounder 34V, 99 F-53 Ford V10 chassis
06 Saturn VUE 4I
MKDSK
Corinth, NY/USA
Go to http://www.fixyourowntv.com/servicemenu.php and there is ways to fix it but I have a Magnavox and it is not listed there.
COxley
Evansville, Indiana, USA
Not sure how late your model of TV is but on my later models there is an up/down adjustment on the remote.
Charlie
MELM
GA
Moving to Technology Corner from Tech Issues.
robatthelake
Vancouver Island
Buy a New TV! Make sure that It is 2009 Complient!
Rob & Jean 90 Southwind John Deere/Oshkosh/Freightliner Class A Ford 460/ Toad 92 Tracker 2 wd 5sp Convert Still running Great!
" Everything in it"Still" Works"
ventrman
Erin, TN
MKDSK wrote: Go to http://www.fixyourowntv.com/servicemenu.php and there is ways to fix it but I have a Magnavox and it is not listed there. http://www.fixyourowntv.com/servicemenu.php
God Bless!
Wherever I happen to park
Well... Drink coffee instead of that other stuff
Several answers here.. The URL others have given may help. I don't know
DE-Gauss... Normally CRT (Picture tube) type televisions do this on power up but if it's been powered for some time,, Unplug, let it sit for a few minutes, plug back in and turn on... Odds of success are very small, but cost is $0.00
If it needs internal repair.. Unless you can do it yourself, replacement is indicated.
Considering that next year we go all digital, And considering the savings in power along from converting from a Pic-Tube job to an LCD or other flat screen, may well pay for the upgrade over time... Consider a digital upgrade now.
