deciding
St. Paul, Minnesota, USA
I'm looking to install some kind of suplimental brake on an older Honda. Have a DP with air brakes. Want something simple to install that isn't a pain to unhook when driving the dingy. Anyone using that SMI air force one? Hard to install? thanks
jauguston
Bellingham, WA
Ready Brake
Jim, Sharon and Buddy the Yorkie
1999 Gulfstream Sun Voyager 31' ISB Cummins 210 uprated to 275
275 RV injectors
Trippe-Lite 1800w inverter 4-6v GC batteries
3- Kyocera 130w solar panels
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
Big Katuna
Deland, FL
I have used a ready Brute tow bar (Ready Brake) with built in surge brake for years and tens of thousands of miles and it works great. Very simple, little if anything to fail and easy to connect and disconnect once the cable is intalled in the car. 8000# rated self locking aluminum and stainless steel tow bar with brake for about $700. Less than most brake systems. That and a $200-$300 baseplate and you are good to go. Here is a LINK
I have talked to many Ready Brake users over the years and we are all a pretty happy bunch. I have heard many stories about problems with the ones that sit on the front floor and use a compressor to push the brake pedal; brakes dragging, burned up rotors and returning units for repair.
My Kharma ran over my Dogma.
skrams
Burlington, Ontario
I am in the process of getting the SMI system in my car. I think it will be a great system, no box to install, just a switch to flip and I am ready to go. I will let you know how it is when I am complete. I am not installing it myself, though most people on here say it is relativly simple.
2007 Four Winds Hurricane 34B (Ford Chassis) Bunkhouse
2007 Chevrolet Cobalt LT (5-speed manual)
SMI Stay-In-Play & Blue-Ox Aventa LX
chasfm11
Dallas/Ft Worth Areas
I have the Brakemaster by Roadmaster. It is similar to the SMI system in that it uses air from the DP's brakes to apply the toad's brakes. The cylinder that I install on each use between a bracket under the front seat and the toad's brake pedal is very light and goes on quickly. I drop the "C" clamp over the pedal and lock it with a pin. There is a clevis pin that ties it to the seat bracket and then I push the air line into the fitting, also under the seat. Including checking the gearshift, the emergency brake and checking that the wheel will turn because the key is in the right position, I'm out of the toad with the cylinder installed in less than 45 seconds. I connect the air line to the front of the toad at the same time at connecting the light wire. The breakaway cable is snapped onto the toad's switch at the same time.
I've been using the system for 4 years and have never had a problem with it. The breakaway cylinder has to periodically purged to keep air out of the piston and that is the only maintenance required. It provides proportional braking and I like it because there is nothing added to the toad's brake system that can lead to problems.
2000 Georgie Boy Landau 36'DP Cummins 5.9, Allison 1000 5sp
1994 Saturn SL1 Toad, Falcon2 Towbar, BrakeMaster Toad Brake
Deen
Vancouver, WA
chasfm11 wrote: I have the Brakemaster by Roadmaster. It is similar to the SMI system in that it uses air from the DP's brakes to apply the toad's brakes. The cylinder that I install on each use between a bracket under the front seat and the toad's brake pedal is very light and goes on quickly. I drop the "C" clamp over the pedal and lock it with a pin. There is a clevis pin that ties it to the seat bracket and then I push the air line into the fitting, also under the seat. Including checking the gearshift, the emergency brake and checking that the wheel will turn because the key is in the right position, I'm out of the toad with the cylinder installed in less than 45 seconds. I connect the air line to the front of the toad at the same time at connecting the light wire. The breakaway cable is snapped onto the toad's switch at the same time.
I've been using the system for 4 years and have never had a problem with it. The breakaway cylinder has to periodically purged to keep air out of the piston and that is the only maintenance required. It provides proportional braking and I like it because there is nothing added to the toad's brake system that can lead to problems. Same here, works well on the Jeep, also have it for the Honda but Honda changed their mind and removed the towing allowed from all Ody's form '05 on. And then they paid us for the towing equipment so we bought a dolly (with brakes)
Deen - Vancouver, WA
'02 Dutch Star 4090 (41+', triple slide)
435/1200 ISC Cummins/Banks PowerPak
'08 Honda Civic/dolly
'05 Honda Odyssey/dolly
NRA Benefactor Life Member
FMCA f47302s, Life Member: Good Sam,
Newmar DP Owners Group
51st yr of RV'ing
Dog Trainer
Richmond Mi.
Check with the chasis manufacture before tying into their air system. Freightliner frowns upon it and Spartan told me the only way they would support SMI is if I bought the Spartan extra air tank setup for $400.00. Try Ready brake as alreasdy suggested or maybe even the US Gear unified tow brake.
93 Airstream 35' Dp
5.9 230 uprated to 300 HP
Allison MD 3060
Dutchess and Shadow (fur Bearing Children)
ramzfam
Appomattox, Va
I have a EvenBrake by Roadmaster that is a breeze to setup and take down. The install was fairly simple and it came with adequate instructions.
Have RV....Will Travel
2007 Forest River Sunseeker 2860 LTD
2000 Jeep Wrangler Sahara
