RV.Net Open Roads Forum: Class A Motorhomes: 180 degree valve extenders
 > 180 degree valve extenders
Farmer Jim
Jasper Indiana
Posted: 04/15/08 08:14am Link  |  Quote  |  Print  |  Notify Moderator
Has anyone used the 180 degree valve extenders on the outer tire of your duel wheels? If you have, how do they work and where did you get them? Thanks Jim
bill h
el segundo
Posted: 04/15/08 08:21am Link  |  Quote  |  Print  |  Notify Moderator
I use them. Got them at CW. They are held on with Loctite. There is a lot of leverage there, so whenever I check pressure or add air, I support the stem/extender from behind to avoid stress on the stem to wheel seal.
So far so good, but next time I buy tires, I am putting on bent one-piece metal stems.
Bill and Susan
84 Barth 30 tag powered by ht502/Thorley, Gear Vendors OD
Siamese Calvin and Airedale Hobbes
4WD Toyota toad
Bumpyroad
Virginia
Posted: 04/15/08 01:35pm Link  |  Quote  |  Print  |  Notify Moderator
any RV store has them, or should
bumpy
chuck4788
West of the Middle
Posted: 04/15/08 06:03pm Link  |  Quote  |  Print  |  Notify Moderator
I have them, solid metal. When checking pressure I sometimes must pull the end away from the wheel hole so I can get the pressure gauge on, they just rotate back against the hole while driving, never had a leaking problem.
Chuck
02 Beaver
505hp C12 Cat
Trailblazer toad
John S.
Northern Virginia
Posted: 04/15/08 06:09pm Link  |  Quote  |  Print  |  Notify Moderator
I had 180 stems put on not extenders but the entire stem.....It works like a charm and it is short and very easy to check and fill.
John
2001 42' Foretravel U320
2007 Bornfree 24 Painted
2001 Jeep Wrangler
2007 Burgman 650 Executive
Susie and Dolly (Cavalier King Charles Spaniels)
Dolly now in our hearts and thoughts 8-27-05
Doodle a Black and Tan Cavalier
Lolly a Ruby Cavalier
JoeH
Apollo Beach,FL
Posted: 04/15/08 06:38pm Link  |  Quote  |  Print  |  Notify Moderator
180 ? Seems like that would turn the valve opening right back to the wheel.right wher it came from .. I have ones that are probably arund 90 degrees
