NotQuiteWT
Central IL
Our Norcold 1200 is having door issues. The left door is setting off the open door alarm all the time. You have to push it in extra hard and it now 'clicks' two times when you push it in. Its real annoying as you think its closed then 5 minutes later its beeping.
Anyone had this issue and been able to fix it?
2006 Excursion 39L - Spartan 350hp Cat
2008 GMC Acadia
2001 Chevy HD lifted 4x4
1995 HD Badboy
All Black!
Dieselgem
Pennsylvania
Have the same issue. I adjusted the hinges several times only to have it happen again. I use a lightweight bungy hooked on the shelf and one of the door trays when in motion. Factory swears its a minor door adjustment. I have not had time to bring it in for service.
08-KZ Escalade 41'CKS Escalade Pics
2008 F450 Super DutyTruck Pics
97 & 2003 FLSTS
2003 FLSTC (Wife's)
MRUSA
Boca Raton, FL
This is a common problem on that model. There are two things you can do. One is to add some thickness ( tape some cardboard there or something)to the part of the inner door that strikes the switch when door is closed, so the switch will be activated sooner. Secondly, you can remove the lower door support and add a nylon washer under the door hinge. This will raise the door and activate the switch sooner/more fully.
Marc, Boca Raton FL
2003 Beaver Monterey 40' triple slide
Blue Ox TruCenter
Acura MDX toad
Unified Tow Brake
Pressure Pro Tire Monitor
Garmin 2610 GPS
Datastorm D3/7000
Sirius Radio
Tivo on board
Dieselgem
Pennsylvania
MRUSA wrote: This is a common problem on that model. There are two things you can do. One is to add some thickness ( tape some cardboard there or something)to the part of the inner door that strikes the switch when door is closed, so the switch will be activated sooner. Secondly, you can remove the lower door support and add a nylon washer under the door hinge. This will raise the door and activate the switch sooner/more fully.
I have taped cardboard, guess its a pretty common thought. I will try to add a nylon washer under the hinge. Thanks
dapark
SLC, UT
Norcold has a kit for about 12 dollars that you can buy that has new nylon washers and other small parts. It is the "door sag repair kit" that can be ordered. I don't have the part number handy but if you want it, let me know and I will post it when I get home. I bought it to fix the latches not locking all the way and it worked for that problem.
2005 Allegro Bay 37DB WH22
1999 Durango is the Toad or
the Milan or the ATVs. Depends on
our compass heading.
voigtrobert
Charleston, SC, USA
Dieselgem wrote: I have taped cardboard, guess its a pretty common thought. I will try to add a nylon washer under the hinge. Thanks
One of the small self-adhesive rubber bumpers for the bottom of small furniture/decorative items is ideal for adding that little bit of thickness that you need to make the switch close sooner.
BobV
'04 42EY American Eagle, 500HP Cummins
'00 Jeep Wrangler Sahara toad
dapark
SLC, UT
Here is the kit that I bought. I also included the link to the parts manual for the norcold 12xx series fridge.
Part# is: 625129 KIT- DOOR SAG REPAIR ( LOWER DOORS) If you go to Click here then click on the "parts list" to open the PDF file, it is shown on page 9 Lower RH Door parts list.
Hope this helps you.
Dieselgem
Pennsylvania
Thanks for the additional ideas.
NotQuiteWT
Central IL
Dieselgem wrote: Thanks for the additional ideas.
Ditto!!
