RV.Net Open Roads Forum: 2005 Yukon XL 2500 tow wiring 12v at truck hitch?
 > 2005 Yukon XL 2500 tow wiring 12v at truck hitch?
nwguy
washington
Posted: 04/16/08 03:47pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 05 Yukon Xl 2500 with tow package but the 12V constant is not hooked up. I talked to the service writers at my local dealer and they said I need to make apmt. I heard it was just a matter of hooking up one wire. it has nothing in the manuel about it. and I don't see anything in the fuse box. I have pulled both and can't find anything not hooked up.
Any help would be super..Thanks
AVid
SE Michigan
Posted: 04/16/08 03:59pm Link  |  Quote  |  Print  |  Notify Moderator
You need to put a 40 amp fuse in the "Stud 1" position in the UBEC. There is a dummy fuse in there, pull it and replace it. The legend is pasted on the underside of the UBEC cover that will tell you where stud 1 is located.
AVid
* This post was edited 04/16/08 05:35pm by AVid *
mapguy
Puget Sound
Posted: 04/16/08 04:52pm Link  |  Quote  |  Print  |  Notify Moderator
AVid wrote:
You need to put a 30 amp fuse in the "Stud 1" position in the UBEC. There is a dummy fuse in there, pull it and replace it. The legend is pasted on the underside of the UBEC cover that will tell you where stud 1 is located.
AVid
Underhood Fuse Panel -believe 40 amp...
Map Guy
AVid
SE Michigan
Posted: 04/16/08 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
You are right and I corrected my post to reflect that. There needs to be a 40 amp fuse in the stud 1 position. Thanks for catching me.
AVid
