RV.Net Open Roads Forum: Toy Haulers: ruby's inn utah...tonight
Search only in Toy Haulers
 > ruby's inn utah...tonight
dwr769
Benicia Ca
Posted: 04/16/08 08:51pm Link  |  Quote  |  Print  |  Notify Moderator
well we are here at ruby's inn campground today its pretty cold, i just noticed that my water hose is froze. any suggestions in the morning on getting water to flow. also looking foward to hitting some of the atv trails in the next couple of days. any suggested rides? we will be heading to Moab on Sunday to met up with friends to ride out there. then back home on the friday after. wind has been pretty strong the past 3-4 days.
brirene
midwest
Posted: 04/16/08 09:15pm Link  |  Quote  |  Print  |  Notify Moderator
Can you unhook both ends, hook them together and bring the whole thing inside?
'04 Jayco Designer 30 RKS
'05 F250 6.0 PSD, FX4, stock
Y-Guy
Tri-Cities, WA
Carefully coil up your hose and bring it inside to defrost, put it out in the morning. You may want to add some water to the tank after it defrosts so you have some for the toilet.
We liked the Badger Creek loop when we rode there last summer.
Have a great time!
Forced Family Fun... They'll thank you later for it!
Have you checked out the new RV.net Blogs?
Supercharged
Az.
Posted: 04/16/08 09:22pm Link  |  Quote  |  Print  |  Notify Moderator
The gift shop there makes more money than than Disneyland.
2005 Chev 5.3 Supercharged 395HP 425 T hp. Two wheels on front, 2 on back. one seat, tint windows. front and rear bumpers, headlights, windows. Door on each side. Heater, floor mats, junk behind seats, some dirt. Pulls so hard.
Golden_HVAC
Fulltime, CA, USA
Posted: 04/16/08 09:36pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
The fastest way to thaw it out will be to put it in a tub of warm water. If you have water in the fresh tank, and can run enough water to fill a bucket and put the hose in it, then that will thaw it out in about 30 minutes.
Otherwise, put the hose into the shower, and it should thaw out overnight and drain down into the shower. If there are showers in the campground, and the hose has not thawed out overnight, then you could put it into the campground shower and run some water over it, until the water can start to flow.
I would not hook up the hose to the RV, but just fill the fresh water tank.
I guess you are lucky that the hose did not burst. This happened to about 20 RV's in this park a couple of months ago when it was down to 26F outside.
It is best to fill the fresh tank, then drain the hose and put it away on nights when it will be below 35F.
If the hose if frozen solid, I would not try to bend it, it might crack. Hopefully the campground store will have some in stock?
You should also shut the gray and black water tank valves and put the hose into a storage compartment that is warmer than the outside air. The hose can be damaged by water in it that can freeze and crack the hose.
Fred.
Money can't buy happiness but somehow it's more comfortable to cry in a Porsche or Country Coach!
If there's a WILL, I want to be in it!
Improve a life KangenPowerTeam.com Akaline Water.
I havn't been everywhere, but it's on my list.
Escapees.com
wildbyon
Tulsa, OK
Posted: 04/18/08 09:51am Link  |  Quote  |  Print  |  Notify Moderator
The best ride(most scenic) in the area IMHO is Castro Canyon. Pine Lake up to Powell Point is nice and there are lots of trails around Tropic Reserviour. Good trout fishing at both Pine lake and Tropic. We did Moab, then Bryce w/ our atv's and tt a couple years ago and it was an awesome trip!
'01 Ford F350-7.3l PS Diesel, Lariet, Crew Cab, 4x4, Dully,
Air bag suspension, performance chip, 4" exhaust
Bulldog ATV Rack
2-'04 Honda 450S Foremen ATV's
'06 Travel Trailer-31'Forest River Cardinal
65TremecGT
So Cal
Posted: 04/18/08 06:08pm Link  |  Quote  |  Print  |  Notify Moderator
Have a great time on the trails up there, we went there last summer and had a blast, Ruby's Inn is a great place!
2006 F-250 Crewcab 4x4 6.0 PSD King Ranch Shorty
2005 Weekend Warrior FK1900 Superlite Toybox, 07 Arctic Cat Prowler
2003 Yamaha Raptor, 82 and 83 ATC 70's, 1981 Honda 185s(Beater)
1965 Ford F-100 Project
