RV.Net Open Roads Forum: Tech Issues: Need help Tire question
 > Need help Tire question
needgas$$
Westland, MI
Posted: 04/17/08 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
I need to replace my tires on my TT. I have ST225/75D15 Duro tires. Please tell me if my memory serves me. ST tires have larger poly cords and a stronger side wall than LT tires? is this correct?
Me & Her
3 of them, Dog
2006 Dodge Ram 2500 Quadcab/hemi/3.73
Reese Dual Cam HP
2004 Puma 30DBSS
dclark1946
Richardson,TX,USA
Posted: 04/17/08 08:53pm Link  |  Quote  |  Print  |  Notify Moderator
If you can get LT tires in your size or close to it make the switch. I have never seen anyone on this forum that switched to LT that had any issues. LT tires meet different (tougher)goverment standards than STs which in general are made as cheaply as possible. I have even used high quality passenger tires on a travel trailer rather than use STs. I had no issues with those either with several thousand miles on them.
Dick
Dick & Karen (converted tent campers)
Richardson,TX
2007 KZ Spree 240RBS
03 Tahoe/04 F250 PSD
Dave Holl
Centerburg Ohio
Posted: 04/18/08 05:18am Link  |  Quote  |  Print  |  Notify Moderator
I would stick with trailer tires (ST) because they're made for towing. I replaced my GY Marathon's (225/75 15" LR "C") with Denman's, same size LR "D". Your tire dealer can order them.
You'll read arguments on both sides of LT versus ST.
You choose.
Dave Holl
F350 with goodies.
24E29 Titanium 5er
Turbo Diesel Dude
Green Mountain, NC
Posted: 04/18/08 06:28am Link  |  Quote  |  Print  |  Notify Moderator
Maxxis ST225 75R 15 load range E
charles weidman
SH
Lynden, WA
Posted: 04/18/08 06:36am Link  |  Quote  |  Print  |  Notify Moderator
I don't believe you can get LT tires in 15 inch. I do believe switching to 16 inch would be the best option if your situation allows it. For our rig, it simply wasn't a viable option. If you are staying with 15 inch rims, either Maxxis or Denman would be a prudent choice. I bought Denman Express ST Radials (made in Mexico) E rated 10 ply. I did have to by new wheels capable of the required 80 PSI. I also had metal valve stems installed.
Best of Luck!
2003 Springdale 279
2007 Chev 2500 LMM Duramax/Allison
1993 Heritage
1989 Sporty
JFG
TN
Posted: 04/18/08 08:09am Link  |  Quote  |  Print  |  Notify Moderator
ST tires have stiffer side walls to help as the trailer moves left and right when being towed. I would stay with ST but get radials load range E.
Fred
dclark1946
Richardson,TX,USA
Posted: 04/18/08 04:50pm Link  |  Quote  |  Print  |  Notify Moderator
Best of Luck!
Yep I have Michelin LT (load range C) tires in 15 inch on our trailer.
Dick
RJsfishin
Winston Or.
Posted: 04/19/08 07:12am Link  |  Quote  |  Print  |  Notify Moderator
True, but for that very reason they also run hotter, wear faster, age quicker, and normally will never see more than a 3 yr life span at best. If you go stump jumpin w/ your trailer, you may need them, but if your trailer's tires don't see any more abuse than your passenger car tires, passenger car radial tires will last longer than anything else on a trailer,....provided that the maximum load ratings are not pushed.
Rich
'98 Flair, 454, Onan Microlite 4k, Intel PD 9155 w/ wizard, Sta-power 1500 watt Inv, 2 6v batts, ammeters, KingDome/sat, Oly Catalytic Heat, hauling 2 Bent Bikes and sometimes towing a Tracker F&S boat.
SH
Lynden, WA
Posted: 04/19/08 09:13am Link  |  Quote  |  Print  |  Notify Moderator
dclark1946 wrote:
Best of Luck!
Dick
Yes you can! The LTX and Cross Terrain come in 15 LR C 35 PSI max. I had meant to say to the OP that I could not find a 15 LT in an E rated tire or one that would meet my rigs (and probably his) weight requirements.
Have a great weekend!
Pete D
Washington
Posted: 04/19/08 07:42pm Link  |  Quote  |  Print  |  Notify Moderator
P radials in trailer use need to have load ratings DOWNgraded by 10%. I tried P-radials on trailer once and took them off at first opportunity -- Trailer waddled all over behind me -- I could even tell the difference just stepping into trailer!! Put STs on trailer, moved P-radials to rear of truck (both 15" wheels) and all was well.
1998 Ranger 4.0 4x4
1991 Scamp 13'
