RV.Net Open Roads Forum: Beginning RVing: Battery Hydro Caps
 > Battery Hydro Caps
jetenbu
Southeast Texas
Posted: 04/17/08 09:42pm Link  |  Quote  |  Print  |  Notify Moderator
Does anyone know where I can get Hydro Caps for my Trojan T-105 batteries? I hear they will help keep your batteries from gassing during charging. Anyone have any experience with them? I did a search but could not find much information about them.
Jim
1996 Holiday Rambler Endeavor LE
Diesel Pusher 37' Kitchen slide
2006 HD Ultra Classic
Protected by Smith and Wesson!
Wherever I happen to park
Posted: 04/18/08 07:43am Link  |  Quote  |  Print  |  Notify Moderator
Hydro caps do not prevent gassing, They encourage the gas (Which is 2 parts hydrogen to one oxygen) to re-form into water and drip back into the battery.
However they do not prevent gassing, Just reduce the effects
jetenbu
Southeast Texas
Posted: 04/18/08 07:58am Link  |  Quote  |  Print  |  Notify Moderator
wa8yxm - Thanks for that information. I misunderstood. Do you have any idea where I might pick up some Hydro Caps? Seems they are a good idea to me.
Posted: 04/18/08 03:08pm Link  |  Quote  |  Print  |  Notify Moderator
Well.. I feed "Hydro caps" to Mr. Google's famous search engine and it replied with some suggestions.. Suggest you do the same.
Also you can check out the better solar houses, they often have them too.
javaseuf
Southern Cal
Posted: 04/18/08 08:11pm Link  |  Quote  |  Print  |  Notify Moderator
Any solar provider.
HERE is one of many I Googled.
Steve
2007 Springdale 291RKL
2003 F150 King Ranch
1991 Palomino Mustang PUP
Eureka Timberline Tent
Yamaha IF2400isc
Yamaha EF3000iSEBC
Rodger
Tucson, AZ.
Posted: 04/18/08 11:31pm Link  |  Quote  |  Print  |  Notify Moderator
Not as much call for them as there use to be because of the new smart converter/chargers. There is also Battery Water Miser Caps. Both can be found at Wind & Sun
Visit My Roadtrek
Hey, check out the new RV.Net Blogs!
jetenbu
Southeast Texas
Posted: 05/15/08 10:02pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks folks for all the feedback. I think I will go with the Water Miser Caps.
g1g
ohio
Posted: 05/16/08 12:05am Link  |  Quote  |  Print  |  Notify Moderator
I have something a little different but very convenient. They are watering caps. A hose connects them to a remote location that is easy to get at and when ever I think they need water I just put on the "bulb" and shoot some water in them. They will stop when it is full. I got them at camping world.
drichert
alpharetta ga
Posted: 07/23/08 08:55am Link  |  Quote  |  Print  |  Notify Moderator
I had 34 Trojan 6V batteries for my Solar system. They were in use for 7 years when I took them out of service and de-activated my system for a few years while I was away. I then replaced all of them with new batteries and just recently started up the system again. I now have 34*3 (102) hydrocaps available. They worked fine....only needed to 'top off' the cells once every 7 months.
Mod. Edit Note: A couple of lines of this post have been removed as one of the Forum Rules states: "You may not use the Open Roads Forum for "For Sale" or "Wanted" posts."
Regards,
David
* This post was edited 07/23/08 11:27am by an administrator/moderator *
