RV.Net Open Roads Forum: Class A Motorhomes: Painting plywood floor
 > Painting plywood floor
wayne_tw
South Dakota/Georgia
Posted: 04/18/08 11:53am Link  |  Quote  |  Print  |  Notify Moderator
dhamblet wrote:
Just so I understand you're ripping out a couple hundred pounds of carpet and/or linoleum on a 15-20,000 pound rig to save gas???????????? Ain't gonna happen. Wanna save gas? slow down, drive less, upgrade the engine to a newer more efficient one. Or simply bite the bullet and pay at the pump. Replace the flooring with linoleum or pergo and enjoy.
EXACTLY!!!!!!!!!!!!!!!
Painting the sub flooring is going to look like sh@t.
Laminate will weigh maybe 50 lbs. and look great.
Worried about extra weight? Why don't you loose about 50 ;bs. each. If you are like me, you can loose that much easy!
itsalleasy
Mine is composite, paint would look terrible, rough to start and soon wear on the high particles. But if you tear the carpet up to install new flooring good marine paint would make a good seal in case of leaks.
I agree with the posts about loosing such a small amount of the total weight to increase mileage. Your results will be noisier, not look that great, and you won't get any better mileage.
deaop01
Mansfield, Ohio
Posted: 04/18/08 12:12pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
I replaced the carpet in my Moto last year. I weighted everything I took out and weighted everything I put in. Difference was 65lbs heavyer. I removed the booth added two chairs and made a bigger table.
I used Prego for the floor. It will weigh 29lbs per box and I used 10 boxes. I also made my own trim from oak.
So 65lbs will not make any difference. Slowing down will get you the most milage. Try 60m/hr and see. I did this for the last 3800 miles and gained almost 2m/gal and I still got to where I was going. Over 300 miles a day 5m/hr won't make much difference except in fuel.
Good luck
Ron
Betty and Ron
2002 Bounder 31W
8.1 with 5 speed Allison
2 slides
2005 Colorado toad
Pokiii
Denver Colorado
Posted: 04/18/08 12:43pm Link  |  Quote  |  Print  |  Notify Moderator
Only paint the floor if you plan on throw woodchip or peanut shell over the top to hide it or you can black out the windows, so in low lights you won't be able to tell,if you don't plan on doing either, I would put the carpet back.
Savannahsv
Lakeland, FL
Posted: 04/18/08 12:54pm Link  |  Quote  |  Print  |  Notify Moderator
If you are not concerned with resale do what makes you happy, but I for one would never buy a rig with painted plywood floors unless it said U haul on the side.
Matt.
2000 American Tradition 40 TVS
'07 Saturn Outlook, Toad .
'96 Cadillac Sedan DeVille
'06 Chevy Equinox
Good Sam
RRV
Two Humans
and three Pups!
janefairlight
Roanoke, VA
Posted: 04/18/08 02:08pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the input. I think you all are right. The only thing we can't do is lose 50lbs. Neither of us are heavy. We do drive very slow. I used to get on my honie's case for driving so slow, but not since we got the RV. He drives about 55 on the highway car or RV. Thanks for all the input.
We did take out the queen bed and put in a nice king foam bed. The mattress that was there was like a rock. We also took out the huge old tv's and got a flat panel. I'm thinking of also taking out one of the dining benches and the little table or extending the table and using a dining chair on one side.
Dale & Jane & Daisy (Shia-poo)
Roanoke, VA
kneal
T
Posted: 04/18/08 09:21pm Link  |  Quote  |  Print  |  Notify Moderator
Take a look at the new floating cork floors. You can easily lay it yourself and it is realitively light weight. We used it in a total airstrem restore project and were extremely pleased.
Neal
Love Boat II
Some where in the USA
Posted: 04/18/08 11:08pm Link  |  Quote  |  Print  |  Notify Moderator
Now that is a good idea
Bench in the back side .
Larger table and 2 chairs .across from bench seat
Captain T. Love (Ret.)
Retired Airline Pilot
CB Chanel 13
AMERICAN AND PROUD OF IT
I WANT MY COUNTRY BACK
BUY USA MADE
http://sagebrushpatriot.com/america.htm
bsinmich
Holland, MI
Posted: 04/19/08 05:57am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like a "Redneck RV" to me. I also noticed someone used Prego flooring on their MH. If you type in Prego instead of Pergo on Google you will not get the desired flooring products. Maybe with a wide roller you can also paint the outside of the RV and get some nice graphics in the process. After taking out the floor in my previous RV I know what kind of flooring they use and there is no way anyone would be happy with that painted.
2003 Newmar Mountain Aire, Workhorse W22, & 2002 PT Cruiser w/Remco lube pump, Falcon 5250, & US Gear Unified Tow Brake
CSpenceFLY
Macon,Ga
Posted: 04/19/08 06:29am Link  |  Quote  |  Print  |  Notify Moderator
My main concern with a bare floor would be noise.
"You're lucky to be alive my friend."
Quote from the "Do it yourself police" and many others that have known me.
