jauguston
Bellingham, WA
The line coming out of the bottom looks a lot like a A/C condenser line. Does the vehicle have A/C? If it does it will look like there are two radiators one in front of the other. The front one will be a little smaller than the back one.
Jim
Jim, Sharon and Buddy the Yorkie
1999 Gulfstream Sun Voyager 31' ISB Cummins 210 uprated to 275
275 RV injectors
Trippe-Lite 1800w inverter 4-6v GC batteries
3- Kyocera 130w solar panels
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
tncruiser
collierville,tn
If it is your tranny cooler you can still add a second cooler. Just put it inline with factory cooler. It's done everyday. That's how I did the one on my previous truck. Also get a good temp. guage. Fords have a test port you can use for the temp. guage line.
Keith & Patty / TN.
2004 27rl Crossroads Cruiser
2006 Ford F-250 Lariat
The older I get. The better I used to be!
happycamper44281
Ohio
We can hear our tranny cooler cycle on/off when we are towing, so can BIL. We both have diesel Silverado's just different years.
2003 Chevy Silverado 2500HD Duramax
2008 Salem LA 312QBBS
Daisy our Shar Pei
chadsalt
sc
happycamper44281 wrote: We can hear our tranny cooler cycle on/off when we are towing, so can BIL. We both have diesel Silverado's just different years.
Huh??
mecreature
Indianapolis, IN
THis is the best I can find out. the 4.8, 5.3, and 6.0 use the same cooler.
At least that what the GMParts direct says
I checked out my 04 your 07 is the same cooler.
edited 04/18/08 03:10pm by mecreature *
smkettner
amaze wrote: It could be your A/C condensor. Would not know for sure unless you follow the lines.
Seems small for the condensor but I don't see a condensor and it does look like one as you say. And I thought most OEM trans coolers were stacked plate instead of tube and fin like a/c condensors. Ultimately the connections will tell what it is.
BenK
SF BayArea
Yes, that should be the plate type ATF external cooler.
Here are two pictures of my Suburban while it was in the autobody shop
after running into that LandRover which jumped a stop sign.
First is the whole front end and the second is a closeup for more
detail. Scanning left to right.
- Very left edge is the engine coolant radiator
- Then the AC condenser which the fan is right on and goes across to the Hydrobooster cooler
- Aux electric fan
- center support with one of the horns
- External ATF cooler...the one your pictures show from the top
- Hydrobooster fluid cooler
Can tell what is what by which type of cooler.
AC is under very high pressure, so fin/tube.
ATF is not under high pressure, so plate type.
Engine radiator is not under high pressure, but is fin/tube, but mainly
because of the historical way of it and that it is very big and plate
types don't come in that sizing, yet.
-Ben Picture of my rig
TXiceman
(Near) Houston,TX
A 4.8L and a 3.23 axle do not make a towing package by any way or shape. Do you mean 3.73?
First it appears that you need a bit more truck or a bit less trailer.
Ken
KE5DFR
Vintage 1979 Silver Streak Supreme Rocket toted by a 2002 F350, crewcab dually, 7.3L,4.10 axle,SCMT. Travel with two miniature Schnauzers and one African Gray parrot. Practicing for retirement!
Two As One
S.E. Iowa
Looks like it,most "towing packs" include a tranny cooler.
dougsee3
Calgary AB
Look in your glove box RPO options
KNP - H.D. TRANSMISSION OIL COOLER
KC4 - ENGINE OIL COOLING SYSTEM
2005 2500 Avalanche
2004 30' Terry Quantum 290FLS
Equal-i-zer,Prodigy
Calgary Alberta
