hoppy55
01129
I Am looking for inverter . can't seem to find it . I looked in outside storage compartments on passenger side where service mgr from dealer said it would be but couldn't find it. I found converter under the bedroom cabinets on drivers side but no inverter. the rear tv is not working while driving . fantastic fans and lights in desk area work but no tv.
OnaQuest
Raleigh, NC
Did the TV ever work while driving? Are you sure you have an inverter? We need more info than you have provided. The lights and fans you mentioned are all 12volts and would work without an inverter.
Dyslexics of the world... UNTIE Visit www.Dyslexics.moc
hoppy55
01129
Thanks for the reply.
the tv's have not worked while driving. but we just bought the unit used this past january and have only driven it twice so far. would the inverter be optional? if so it doesn't seem to be listed on copy of invoice.
96Bounder30E
Birthplace of the Boysenberry, Orange County, CA
An Inverter would be optional.......a Converter is standard equipment....
I doubt very much that your Bounder came with a factory installed iverter.....My buddies 2006 Southwind did not.......
Eric
96 Bounder 30E-F53(460)
stock Ford intake w/K&N air filter
used Thorley headers
new Banks resonator, muffler, tail pipe and 4" polished SS exhaust tip
Golden_HVAC
Fulltime, CA, USA
hoppy55 wrote: I Am looking for inverter . can't seem to find it . I looked in outside storage compartments on passenger side where service mgr from dealer said it would be but couldn't find it. I found converter under the bedroom cabinets on drivers side but no inverter. the rear tv is not working while driving . fantastic fans and lights in desk area work but no tv.
Hi,
Most of the light, the fantastic fans, and such all run on 12 VDC, so they do not require an inverter to work. If there is no factory installed inverter in the factory location, then it probably was not factory installed, it is kinda rare for someone to order a factory inverter.
In recent years inverters have become much more affordable. So a 500W inverter from Costco will only cost around $30 and can plug into a cigarette lighter. You can also hard wire them to #10 gauge wire for up to 300 watts output, or #6 wire for up to 500 watts output.
What I did in my RV was install a new cigarette lighter near the front TV. I found some #8 wire up there, and tapped into that for power - connected to a 20 amp fuse. I bought the cigarette lighter receptacle at Radio Shack. I have used them with up to 30 amps going through them for short times, without them overheating. But it is best to stay below 200 watts, or to wire the inverter directly to a fused wire.
There should be a 12 volt cigarette ligher receptacle behind the rear TV, but I don't know for sure. On my TV signal booster, there is a cigarette lighter receptacle, but it is fused at only 5 amps, so I put in a better one.
Fred.
Money can't buy happiness but somehow it's more comfortable to cry in a Porsche or Country Coach!
If there's a WILL, I want to be in it!
Improve a life KangenPowerTeam.com Akaline Water.
I havn't been everywhere, but it's on my list.
Escapees.com
Bounder Billy
Colorado
I have an inverter in my 2006 35E and it is on the passenger side in the second storage bin to the left of the steps. It is the same bin where the hot water heater bypass is located. Hope this helps.
2006 Bounder 35E
hoppy55
01129
thanks for the help
will probably just pickup cig. lighter plug in inverter for now and use generator also. leaving tomorrow for virginia and then s.c.
