RV.Net Open Roads Forum: Fifth-Wheels: Sani-Flush question
 > Sani-Flush question
kennethwooster
Perryton Tx USA
Posted: 04/19/08 07:46am Link  |  Quote  |  Print  |  Notify Moderator
I keep a gray hose for the tank flush. I try to be careful, even though there are anti-back flush. It's just not worth the chance of getting us sick.
kenneth wooster- farmer
wife Diana-adult probation officer
365BSQS Quad slide 2007 Quantum
Ford F350 2005 model, 4X4 FX, King Ranch
18K SuperGlide Hitch
timandsusan
San Antonio, Texas
Posted: 04/19/08 08:21am Link  |  Quote  |  Print  |  Notify Moderator
I use 2 hoses. But the sani-flush hose is only connected when I flush the black tank. There is no need to connect it until you are going to use it. I also use the flushing hose to wash out the sewer hose--Don't ever use my white fresh water hose for any of this.
Glen41
North Texas
Posted: 04/19/08 08:24am Link  |  Quote  |  Print  |  Notify Moderator
On a related issue. Does anyone test the campground water before using it? It used to be a big issue when hiking, and everyone carried these little test kits around.
I would not be too worried in an urban site (city water), but some of the rural ones are on a local well and the pipes have been there a long time.
Fun is that stuff that happens in between mistakes.
2006 Chevy 3500 D/A DRW Prodigy, AirBags, CoPilot, EarPlugs
34 ft River Canyon with most of the pieces still attached
lambchop
WI
Posted: 04/19/08 08:30am Link  |  Quote  |  Print  |  Notify Moderator
I use an anti-back valve, like the ones that are on a lot of RV water hook-up's at the parks. Also I use a separate hose.
I see people all the time using their white fresh water hose to flush....Yuck!
Lambchop
2008 33 ft. Montana 5th wheel
2000 3/4T Chevrolet Truck 6.0L 4:10
grampachet
West Coast
Posted: 04/19/08 11:30am Link  |  Quote  |  Print  |  Notify Moderator
This is just a question, OK?
Where would any pressure come from on the sani-flush to cause it to enter the pressurized fresh water hose. Then with the anti-siphon attachment and a shutoff how would it be possible to have any contamination problem?
2004 F-250 KR,CC,SB,SRW,4x4,V-10,3.73
2008 Montana 3000RK
psneeld
Cape May, NJ
Posted: 04/20/08 06:09am Link  |  Quote  |  Print  |  Notify Moderator
I can see not leaving a permanent connection between the sani and the fresh water...but I use a short jumper just off my city water to the sani inlet when I want to flush.
I only do it when the black tank has been dumped so I agree with those who say where would the siphon occur....and there is positive flow and pressure away from the fresh virtually the whole time the hose is hooked up.
Been doing it this way for years....but would change if someone could really convince me it is dangerously unsanitary.
Laura & Scott Neeld
2004 Arctic Fox 29-5T
2001 F250SD EC PSD 4X4, Prodigy, Pullrite Superglide, Timbrens
ttstansfield
tulsa
Posted: 04/20/08 07:11am Link  |  Quote  |  Print  |  Notify Moderator
Gravity is irrelevant. Changes in pressure can cause "backflow". On ships we have Backflow preventers to avoid this very thing. Just a fancy one way non-return valve. However, is it all worth it just to avoid swapping a hose over? If you are worried about the durability of the fittings on the trailer, just swap the hoses at the Campground end, and leave the two connected at the trailer.
Tony
TheFollands
Corona, CA
Posted: 04/21/08 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
I took my rig to an RV dump just this weekend and used our Sani-flush system. When I disconnected my hose (the host from the rv dump), water back-flowed out of the sani-flush connection. While this water was clear, there is no doubt in my mind that this was contaminated water. I would definitely use a seperate hose.
2007.5 Chevy Silverado 3500 Crew Cab Dually
2009 Weekend Warrior 3905 SLC Dual Slide
2006 LTZ400 Quad (Dad)
2007 LTZ50 Quad (Son)
2007 Joyner 650cc Buggy (Wife)
1 Beautiful Wife
1 3.5yo Handsome Son
1 Spoiled Rotten Chihuahua
Bumpyroad
Virginia
Posted: 04/21/08 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
In theory, that large gush of water that comes out is from the clean side of the back flow preventer but I too feel that there is a possibility of contamination, however slight. that is why I always keep my water under pressure when unhooking.
bumpy
