budd
palm city , florida
have a Coachmen Marida ds-2006- 10500 miles --has one house barrtery--only shows charging on the gauges in the coach , when the RV engine is running--does not show charge when plug in to land power ,nor does it show when Generator is running--any body ?? have a 50amp gen--
strange-
thanks Bud
dave Stringham
I was hoping you'd know, California
Inverter
COxley
Evansville, Indiana, USA
I agree, inverter>
Charlie
OnaQuest
Raleigh, NC
What am I missing here? How did/do either of you responders even know if Budd has an inverter? I would say there is something wrong with the CONverter/battery charger. jmho. lou
Dyslexics of the world... UNTIE Visit www.Dyslexics.moc
dave Stringham
OnaQuest wrote: What am I missing here? How did/do either of you responders even know if Budd has an inverter? I would say there is something wrong with the CONverter/battery charger. jmho. lou
Inverter/Converter.....potato/potahto.....it gets him to the right place to begin to look
OnaQuest
Raleigh, NC
dave Stringham wrote: OnaQuest wrote: What am I missing here? How did/do either of you responders even know if Budd has an inverter? I would say there is something wrong with the CONverter/battery charger. jmho. lou
What a crock!!
If you don't know what you are talking about, then why respond?
dave Stringham
OnaQuest wrote: dave Stringham wrote: OnaQuest wrote: What am I missing here? How did/do either of you responders even know if Budd has an inverter? I would say there is something wrong with the CONverter/battery charger. jmho. lou
What a crock!!
Excuse me Mr Redi-Volt
Hurricaner
Hurricane Utah
More than likely it is a problem with the Inverter/charger or converter/charger, which ever one your unit came equipped with. A inverter/charger in addition to charging the batteries will also invert 12 volts DC to 120 volts AC.
Sam
Sam & Kari
Hurricane, Utah
2004 34' Damon Challenger 315
Damon owners forum
OnaQuest
Raleigh, NC
dave Stringham wrote: OnaQuest wrote: dave Stringham wrote: OnaQuest wrote: What am I missing here? How did/do either of you responders even know if Budd has an inverter? I would say there is something wrong with the CONverter/battery charger. jmho. lou
What a crock!!
Dave, at least you are consistent. The quality of BOTH your answers was the same. Keep up the good work.
jeep2relax
Lakeside, CA
"--only shows charging on the gauges in the coach , when the RV engine is running--"
What gauges are you looking at?
The gauge on the Dash for the engine will not read charge unless the engine is running.
Did you put a volt meter on the house battery to check for charging?
