RV.Net Open Roads Forum: Fifth-Wheels: Sloppy!! Help Me hitch Guru's. Please!
 > Sloppy!! Help Me hitch Guru's. Please!
markpp
chandler AZ
Posted: 04/21/08 04:14pm Link  |  Quote  |  Print  |  Notify Moderator
My stats. new to pulling FW. 2006 Dodge swb 2500 diesel pulling a 32ft Holiday Rambler Alumalite. New 16k Reese slider hitch and just added a Moryde pin box. Have only pulled FW about four times locally. Each time have heard a lot of banging going on back at the hitch area, but couldn't tell what was going because I was always by myself. A friend helped me this weekend install the Moryde pin box and you definitely need help. We went and took it for a test run and the Moryde is doing it's job. However it could do better if there wasn't so much slop in the slider hitch.
I was now able to see what the banging sound was all about while my friend drove and I observed. When you take off the “A frame” which holds the swivel head and has the rollers, locking device, etc., lifts up somewhat off “slop” the tracks that are bolted to the bed. But man you should see what happens when you make a sudden quick slow down or stop. The maneuvering tow handle almost comes straight up and the banging going on isn't nice. I would think a product from Reese would be a little tighter or do I need to do some kind of adjustment; or is this just the way it is? Does Pullrite supergilde and others do this? When I bought the FW the dealer installed the rails hitch and head. Thanks for your time
ssouder
Shippensburg PA
Posted: 04/21/08 04:34pm Link  |  Quote  |  Print  |  Notify Moderator
I'm having the same concerns. I was going to post the same question. Is there a way to stop that slop. At a club campout this weekend, another guy that has a slider hitch of a different brand. He used pieces of roof rubber maybe 2 inches square between the slide rails and the bed rails and then one under each slider roller. He said it made a hugh difference but wasn't sure it would be a long term solution. I will be very interested with the responses.
Thanks
Steve
2007 3500 Dodge 4x2 QC 5.9 CTD 4.10
2005 HitchHiiker Discover America 31 1/2 LKTG
tncruiser
collierville,tn
Posted: 04/21/08 04:45pm Link  |  Quote  |  Print  |  Notify Moderator
I have almost the same setup as you, but I don't have any movement in my hitch. The frames set tight in the bed rails. What you are describing almost sounds dangerous. I don't think I could tow like that. Are you sure the pins are the right size. My frames have to be almost perfectly aligned before it will set in the rails. I have heard of people having slop before, but I didn't think it was what you have described. Anyone else have a hitch this loose?
Keith & Patty / TN.
2004 27rl Crossroads Cruiser
2006 Ford F-250 Lariat
The older I get. The better I used to be!
CactusJohn
Scottsdale, AZ
Posted: 04/21/08 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
I have the 16K slider, but don't understand the problem you're having. You said the maneuvering handle went straight up. Does that mean it wasn't locked in? When you move that handle to either the tow or maneuvering position, move it as far as you can toward the position you want, either tow or maneuvering, before moving the truck to lock it in. Don't put it in the 12 o'clock position, because that won't allow it to lock in when you slide the 5er. Also, hold your 5er brakes manually when you're moving the slider.
2007 Ameri-Camp Summit Ridge SF27RK 5er
2008 F250 Lariat SuperCab, 6.4L PSD
Reese 16K Kwik-Slide with BedSaver
pritch272
Martinez, GA
Posted: 04/21/08 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
I might not have the same hitch as you, but there is absolutely no slop at all, very solid, even when we hit a dip or 2, still one unit. I'd be concerned with any movement, seems that it could only make things worse.
Retired US Army
2000 Ford F250 SD 7.3 PSD, Firestone Ride-Rite™ air springs
2007 Keystone Laredo 29RL, Doran Pressure Pro and Metal Tire Valves, 16" Michelin XPS Ribs, Dirt Devil CV950 Central Vacuum, 2000W AllPower (Honda Clone), 4000/3500W Champion C46540
Airbus 9e
Rochester, NY
Posted: 04/21/08 05:47pm Link  |  Quote  |  Print  |  Notify Moderator
I have the exact same setup, and have no issues with "slop"....
Sounds like maybe an improper installation?
2004 Dodge Ram 2500 QuadCab 4X4 HEMI
2004 Cougar 285 EFS Fifth-wheel
....and a Dachshund named "Walley"
..."can't sleep.....clowns will eat me."....
ryoung
Indiana
Posted: 04/21/08 06:02pm Link  |  Quote  |  Print  |  Notify Moderator
Are you towing with the hitch in the rear (maneuver) position? Surely hope not.
ryoung
2004 Dodge 3500 Dually HO 6 sp 4.10, Jordan Controller
2005 SunnyBrook 31BWKS
2004 Lance Lite 915
Vulcaneer
Northern New England
Posted: 04/21/08 07:12pm Link  |  Quote  |  Print  |  Notify Moderator
Since you asked about the PullRite SuperGlide, I can tell you this hitch has an adjustment to take up any shucking. I have no problems in that regard.
My nephew has an older Reese non slider that is not nearly as solid. But I would think the new Reese Hitches would be better. Sound like something may need attention.
2006 F350 V10 4X4 SC SB SRW 4.30 22,500 GCWR
Keystone Sprinter 33'9" 12,500 GVWR
Pullrite Super Glide 18K
Super Duty, Super Cab, SuperGlide
SEE RV.net Classified for Vette Description
mark1228
Helena, MT
Posted: 04/21/08 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
Vulcaneer,
How do you like the PullRite? Any problems?
kennethwooster
Perryton Tx USA
Posted: 04/21/08 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
I've used several different brands. Some would bang, but nothing like you are describing. We went to the Super Glide this winter. That is one sweet hitch. I know it costs more, but even with the MorRide extended king pin we still took out the rear window. That made the hitch look cheap. Between the Morride pin, and mor ride suspension things are just smoother.
kenneth wooster- farmer
wife Diana-adult probation officer
365BSQS Quad slide 2007 Quantum
Ford F350 2005 model, 4X4 FX, King Ranch
18K SuperGlide Hitch
